This unit was made at basically zero cost. The transformer was salvaged from an old oil furnace, the power cord was cut off a discarded appliance, and the wires laying around the shop. Have fun and be safe.
Remove these ads by
Signing UpStep 1Safety First - Extreme Electric Shock Hazard!
ALWAYS disconnect the power before working on it, or adjusting anything.
DO NOT touch the terminals or rods when the transformer is energized.
DO NOT put anything conductive (including you) close to the terminals or rods when the transformer is energized.
DO NOT do anything stupid.
Transformers of this type do not vibrate, make noise, light up, or let you know they are energized in any way. Just because there is no arc does not mean the unit is safe. Always check to make sure it's unplugged before handling.
I don't know for sure since I've never done it, but I wouldn't try it.
Vince
they output only 2.5kv and too many amps.
you need at least about 9kv (give or take)
at 20 miliamps and i can tell you first hand it hurts like hell! my glove insulation had a whole and i took the brunt of the shock down my right arm and out my right leg and ive been told be numerous electricians im lucky to be alive =P so BE CAREFUL and always work with your left hand behind your back(in the event of a shock this helps keep an arc from forming over your heart possibly sending it in to venticular fibrilation)
The point is, these transformers can seriously hurt or burn you and I would not be surprised if one killed you.
And, I do not think 12 year olds should be messing with these unless you are under supervision of an adult or electrician.
