Low Cost LED Light Using Old Mobile Battery
32,053
27
15
Published
Introduction: Low Cost LED Light Using Old Mobile Battery
This is very low cost and efficient LED light System ,using waste material .
This is better than HOME LIGHT product from eveready
because u can recharge it from your nokia mobile charger .
it contains 22 LEDs so it is very bright.
and you can use more than 24 hrs on every charging.
Step 1: Requrements
All stuff you need
1. [box]
1. [nokia charger female connector]
(u can get it from any nokia charger converter ,that converts big to small connectors).
1.[switch]
1.[10 ohm resister]
1.[100 ohm 1/2watt resister]
22 .[WHITE LEDs]
1. [old any phone battery 3.7 volts]
1. [nokia charger for charging]
Step 2: The Circuit
This is very easy circuit.
Step 3:
take a empty box
Step 4: Measure for Hole
take box and measure for holes.
then mark for hole also mark holes.
Step 5: Insert Switch
Step 6: Insert LEDs
insert LEDs as shown below
Step 7: Connect Every Thing As Shown in Circuit
connect every thing as shown in circuit.
Step 8: Final Product
That is ur final project
U can use it more than 24 Hrs.
and just charge it 1 Hr every time u need.
this is my first instructable so let me know if i m wrong.
Thanks every one !!!!!!
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    15 Comments
    and is it possible to use a solar panel to the project with the LDR, what size of solar panel would i require as my village receives alot of sunlight. so it becomes easier for us to charge. thanking you sir.
    Hi is it possible to add an LDR to the project ? if yes where can i add it?
    Hello fantastic idea. I am looking for solutions for my project making lamps out of beer cans and the best thing I found was to light them with old phone chargers. Your idea is cool I can make them wireless and rechargeable!
    how to add charging indicator light in this project plz tell me
    Did you wire all the LED'S in seires?Because I see that you only used 1 resistor.I think it was running of 12vdc.
    tks
    Johnny
    no buddy all are in series . the resister is for only work as protector . i m  using 3.7 volt nokia batt not 12 volt
    How are the LEDs wired together - parallel? Not familiar with calling resistors registers... L
    The picture says series, but they must actually be parallel considering the battery voltage used. A better question is how quickly will it fry the lithium ion cell with no charge regulator circuit.
    ya man,the li-ion battery cannot be charger directly from the charger output!!!
    it requires a "intelligent" charger. built around a li-ion charger IC such as the bq2000 from T.I.check this out.usually such charge regulator circuits are built-in to the mobile phone!!
    the circuit is for 4.2v cells.will it work with the 3.7v bl-5c nokia cells?
    Or, if you have a mobile phone that still charges but doesn't work as a phone (broken screen, broken aerial or whatever) you could put the whole phone in the light and use it as a charge regulator- most recent phones will charge even if switched off, and should draw minimal current from the battery.
    The charging is regulated, discharge is pretty heavy though. L
    This is a neat Instructable, and a clever design for a portable rechargeable light (might make a bike headlight like this...). My only criticism would be your circuit "diagram"- while I can understand it it isn't very clear to read. Providing a circuit diagram drawn with straight orthogonal (horizontal/vertical) lines and the conventional symbols for components (or a drawing if they don't have one) will make your circuit easier to understand.
    Thanks guys for correction. well every thing is ok now . i m using this very fine no problem with charging but remember one thing don't charge it more than 2 hours .
