If you'd like to have your own multi-touch whiteboard, drafting table, or tablet PC. You can make one using a Wii remote and some IR leds pens. The IR camera in the Wiimote will track the location of the pens. With a little bit of software, you can map the camera data to the display position so you can use the stylus just like a mouse.
The software is available to download from my website at
http://johnnylee.net
I was thinking of putting the leds on fingertips of a glove (4 fingers), will that work?
Is there a way to make windows 7 recognize the input as a tablet/pen input interface (instead of a really big, fancy touch mouse as with smart boards) so I can have a full touchscreen experience? That would be really cool.
Thanks
I just bought an IR-pen (Sabre). I also have a wiimote, but i have no beamer.
I tried to calibrate my pen, but it won't work. I have the software, i press calibrate, and the white screen apears with the red crosses. I press al 4 of them with my pen, but afterwards, nothing happens: i can't control my pc with my pen..
I've put my wiimote in the right position, but it won't work..
What am i doing wrong?
Thq..
At the moment, Wii Remote is the most cost-effective capturing device to turn your screen into an interactive whiteboard. This is because of the low latency and the relatively high resolution of the Wii Remote's camera. If you are using a web camera, your computer may need to handle a lot of processing to extract the dots.
You can take a look at this video to see how easy the interactive whiteboard can be set up.
Regards,
Boon Jin
http://www.smoothboard.net
Jackie Lee
Profession Interactive IR Pen for wiimote from Oway Group Limited
You will need to skip the passcode. If the Skip button is not present, you can press Alt+S on your keyboard.
If you would like to automatically connect the Wiimote with Smoothboard, you can use the Microsoft Bluetooth Stack.
For more information you can take a look at the Smoothboard- Wiimote Whiteboard wiki at http://www.boonjin.com/smoothboard.
Regards,
Boon Jin
You can use any flat surface including your monitor.
If your screen is small, you may find difficulties clicking on a small spot as the IR pen's tip will be quite large in comparison to the screen pixel. :)
Here is an example of using an LCD screen.
www.instructables.com/id/DIY-Cintiq-Tablet-using-Wii-Remote/
Regards,
Boon Jin
www.smoothboard.net
Wii Remote is the most cost-effective solution for interactive whiteboard. You can look at http://www.instructables.com/id/Interactive-Multitouch-Display/ to find out another option. But you need to upgrade your webcam with a IR-only light filter and many works on installing ir lights. It might takes you weeks to get all things done :(
iWiiBoard has a great solution for wiimote whiteboard. You can check it out
The Smoothboard software can be downloaded from www.smoothboard.net/download
For more information on connecting the Wiimote on your computer, you can take a look at www.boonjin.com/smoothboard/index.php
You cant directly connect a wii remote to a PC, you need to have abluetooth dongle plugged in your PC to talk to wii remote. And you need a bluetooth dongle software to pair your wii remote.
iWiiBoard has a built-in automated wiimote connect feature,which will save you lots of time on pairing your wii remote.
I can directly connect my wiimote to my computer, as long as you have a new mac or pc.
It may be that your ir pen has too wide of angle?
It seems that the Wiimote is not detecing the IR source of the pen correctly.
Normally, this is caused by your IR pen blinking by itself (connection issue internally) or a non-genuine/faulty Wiimote where it could not track the IR point continuously due to Wiimote's camera sensor.
How big is the screen you are trying to calibrate?
In Smoothboard, you can turn to Presenter Mode and face the IR pen directly at the Wiimote to see whether the IR dot still flashes. If it still flashes, it means the IR pen is faulty (blinking) or if you have a permanent IR dot when near but not when far, it means the IR source is weak or the Wiimote is faulty.
Smoothboard now comes with autoconnect mode that does not require bluetooth. It has annotation features too.
Check it out at http://www.smoothboard.net
Smoothboard has an easy to access toolbar that provides annotation capabilities and navigation controls for your presentations.
The latest Smoothboard release can be downloaded from http://www.smoothboard.net
