Low Cost Rotary Laser Level
16,218
116
15
Posted
Introduction: Low Cost Rotary Laser Level
I have been asked to design and build a large raised level pond that is wheelchair friendly. It has a very small free board of 70mm from water surface to top of the raised sides. It will need some accurate building work, I realised that the best way to go would be to use a rotary level to draw a laser line all the way around to survey in the edges.
As this is for outside use my thoughts were that a green laser was essential for visibility..... the cost of such a device online was prohibitive so I put my thinking cap on to work out a way to make my own, low cost, version.
Step 1: Design Thoughts
The professionally built laser levels all have the line projecting from the top of the unit, I decided to turn the whole thing on its head as using gravity would save me from having to design a complicated gimbol unit to level the projected line.
To help gravity along I wanted this to have some weight to it so I chose brass, a nice dense metal, for the chassis. To make it even heavier I decided to mount all control and power on the chassis too, no trailing wires or plugs and sockets.
Step 2: Parts List
The first Items I had already in stock but I will suggest suppliers I have used in the past.
1.2mm Brass offcuts
Brass tube of a size to suit your laser module
Silver solder, soft solder, fluxes
Various screws, nuts and washers.
Super glue
Small piece of front surface 3mm plastic Mirror
Green laser module Deal-extreme-laser-module
Small 3v dc motor (with gearbox removed) reichelt-small-dc-motor
2 x single channel remote control relay units & 2 button remote fob Deal-extreme-remote-relay
4mm D shackle shackle
4mm x 40mm Carabina
I used reichelt, for the outstanding electrical parts. reichelt home
2 x AA-battery-holder
4 x AA li-ion rechargable 3.7v batteries
Step 3: Tools Required
I am fortunate that I have a fully equipped workshop and I will make good use of Lathe mill and drill, this build can however be hand built with the following.
Hand drill and bits
Hacksaw
Heavy tin snips
Files various
Gas torch
Large soldering iron
Bench vice
Wire wool ( cleaning for soldering)
Emery cloth
.....and whatever else you can see in the mess that is my workspace :)
Step 4: Other Design Thoughts
There are many very good reasons for using brass for the chassis,
it can be easily cut drilled and formed when annealed
It can be silver soldered (high temperature)
Soft soldered (low temperature)
Super glued (room temperature)
it is very stable once work hardened
It looks nice
It doesn't need to be painted
The idea of the chassis is to make it as thin as possible so that the section of the circle not lit by the laser is as small as possible, wires from the motor run up through tubes either side of the main support plate. The design also allows for "tweeking" to get a flat line once the build is finished.
I decided on using a remote fob to turn it on and off as it uses quite a lot of battery power (More of this later).
Step 5: The Electrics
The wiring turned out to be quite complicated due to the fact that remote control relays need a minimum of 6 volts and the laser and motor need a maximum of 3 volts.
The starting point is to use 4 of the 3,7 volt re-chargeable batteries with the same size as AA batteries.
Modifying a pair of twin battery holders to get both required voltages turned out to be the answer.
Step 6: Remote Relay Supply 7.4V
The relay boards can be run from 2 x 3.7volt batteries in series giving an output of 7.4 volts, the only modification to the holder is that I inserted a small slide switch in the top to allow the power to be turned off, this is the only switch required. This is the right hand holder in the second picture.
Step 7: Laser and Motor Supply 3.0 Volts
The laser and motor can be run from 2 x 3.7volt batteries in parallel giving an output of 3.7 volts.
The contacts need to be modified to move both springs to one end and both positive terminals to the other end, in addition I added an IN4001 rectifier diode in the positive feed, this has the effect of dropping the output voltage by 0.7 volts so that we get the desired 3.0 volts.
Step 8: The Chassis
There are no dimensioned drawings for this as a "one off" it was all done by the suck it and see principal.
The main plate was made long enough to attach a motor, a laser and a hanging up arrangement and had to be wide enough to attach the battery holders.
The spine needed to wide enough and long enough to mount the relay boards, the piece of tube needs to be a good fit on the laser module.
The motor plate was silver soldered to the main plate, the laser tube and the spine were soft soldered in place.
I also soldered the tubes for the motor wires along the junction of the main plate and the spine but these could be super glued in place.
Step 9: Covering the Motor and Its Wiring
I wanted a nice clean design with no visible wiring, the afore mentioned wiring tubes hide the motor wires as they pass the laser and ensure that the area of the chassis that the laser hits is as small as possible.
The motor cover is a simple fabrication of brass sheet, bent into shape and silver soldered together, it protects the motor and hides the wires.
Step 10: Covering the Laser Driver and Its Wires
I made a cap for the top end of the laser out of a small piece of tube with one end blocked off and two short pieces of tube inset for hiding the laser wiring. This was all soldered together and is a good fit into another piece of tube that slides over the back end of the laser module
Step 11: The Rotary Mirror
This is by far the hardest bit to get right I can only tell you in a few words what to do.
The mirror needs to mount at exactly 45 degrees, it is mounted on a piece of round brass 8mm diameter with a hole in it to fit the motor shaft.
. I cut my brass rod by hand, holding it in the vice, using a hacksaw and a set square with a 45 degree side to get it as close to 45 deg as I could. I tickled it up with a fine file until I was happy with the angle.
A small piece of plastic mirror is then stuck on top with superglue. and filed to the finished round shape.
On final assembly I used a dot of superglue to stick the mirror mount to the motor shaft.
Step 12: Adjustable Mount
The assembly is symmetrical left to right so it hangs perfectly straight in that plane. Weight front to back is not at all even which is why I cut an 8mm slot in the top of the chassis to make the hanging point movable to get it to hang correctly.
To make the pivot I found a short M8 brass nut and bolt, thinned down the head and the nut and drilled it through to the size of the shackle, 4mm in my case.
Step 13: Testing
The frame could have been tweeked if needs be to get the line correct but I found there was no need, I set it up using a water tube....(no photo's of this process I am afraid as my computer died after a windows update and those photo's were lost :( I will describe it below).
Mrs rog and I filled a length of tube with coloured water, set the laser level running then took one end of the pipe each to compare the height of water to the laser line out to the sides. (it was within 6mm over 20m). There was an obvious high to the front, low to the back thing going on so I moved the hanging point until it was evened out. The last test is to have one end of the tube right next to the laser and the other out as far as possible. This is where any error in the 45 degree mirror shows most, my build was slightly out but is near enough for my purposes.
Here is a quick video showing it in operation, the camera doesn't pick up the line as well as the naked eye.
Low cost laser level from Rog8811 on Vimeo.
2 People Made This Project!
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
9 Comments
Just a note of safety, always try to use googles as (ANY!) laser light is dangerous for the eyes and never look directly into the beam or the reflection.
Othervise great project (voted)
Also an addition to the plastic mirror is you can extract some pretty small and good quality mirrors from CD/DVD drive (50%reflection tho) but they are 45degrees
Good point Dm, I have used used them in the past with green lasers they reflect very well.
Did you do any calibration/testing after making this? It seems like it would be very easy to have this be misaligned in a few ways; 1) getting that mirror exactly 45. Otherwise you'll have a cone instead of a circle, and the futher away you get the higher/lower the line will be. And 2), having the whole assembling tilted a bit. Then one side would be higher/lower.
The latter is easy to test; put the device somewhere, mark the heights. Then rotate the device 180. If it's tilted, you'll see a difference in marks. You can keep adjusting until the marks are the same regardless of rotation.
For the first, it's a little harder. Easiest way here is to measure it, then turn the device upside down & remeasure. If the mirror angle is off, you'll see it here.
This is a really nice idea, very cool. With a good way to calibrate it, this could be a nice alternative to store-bought laser levels.
Hi JF, The testing with the water tube was all that I needed to do, it is close enough to a flat line for my purposes. Out of interest I had to swap out the first laser module I tried as the beam came out at quite an angle. I would probably make the laser mount more adjustable if I did it again.
As to ongoing calibration I have discovered that my workshop timbers are very very close to horizontal and if I hang this from a roof beam I can see the beam all round and eye up how it looks to a plank line :)
Excellent Instructable; both well thought out and executed. I'm not sure the remote is necessary as there are switches that are extremely small and lightweight - probably more so than the relays (which are, after all, just electrically operated switches). It certainly adds a bit of class and makes it look "more professional".
Thanks for the input JGD, I opted for the remote switching for a number of reasons amongst which is it saves the leg work keep returning to it to turn on and off between checking levels, it is quite battery hungry :)
Another one that I felt would be useful was for additional mass for damping, you may notice in the video that when the motor starts the unit precesses slightly, I reasoned more weight the quicker it would settle.
Very good job indeed. Two minor points however :
1) relays exist in 3V and most 5V relays will work at 3V
2) the mirror doesn't need to be "exactly" at 45°, which is almost impossible, as it will anyway discribe a circle in the same plan.
Hi, Thanks for the comments, I would say though:
1) Relays can indeed operate from lower voltage, these relays are remote control operated and the remote circuits need between 5v and 8v had I managed to find some that used a lower voltage I would have used them.
2) Sorry but the only situation where what you say is correct is if the level is in the middle of a perfect circle, hang it in the middle of a square room and the line will describe four curved lines..... I have attached a drawing to illustrate the effect. In my hypothetical square room the laser, as drawn, would project a line with the lowest point in the middle of the wall and the highest point in the corners.
