Low Cost Video Stabilizer
22,416
446
18
Posted
Introduction: Low Cost Video Stabilizer
Video stabilizers are used to improve the smoothness of video when the operator is in motion. Professional version cost in excess of $500. The version shown below can support the weight of a DLSR camera and is made from less than $25 of materials. I’ve also included a video of the stabilizer in use along with a PDF version of the plans.
Drawing File:
https://docs.google.com/file/d/0B21TbB8gGNQbMldmcE...
Video:
Step 1: Tools
  • Tape measure
  • Saw
Step 2: Materials
Step 3: Top Level
Follow these views for the build.
Step 4: Cut Pipes and Organize Parts
Cut the ¾” PVC pipe as shown in the material list.
Step 5: Side 1
Assemble first side as shown. You will use five (5) 1 ¾” length pipes, one (1) 3” pipe, and one (1) 24 ½” pipes.
Step 6: Side 2
Assemble the second side which is a mirror image of the first side.
Step 7: Cross Support Assy
Assemble cross assembly as shown. You will use two (2) 4” pipes and one (1) 3” pipe. Repeat process to build a second assembly.
Step 8: Camera Mount
Drill hole through cap. Insert ¼-20. Captivate bolt with ¼-20 nut.
Step 9: Assembly
Connect Side 1 to Side 2 with the two (2) cross support assemblies and the two (2) 9 1/8” pipes. Add the camera mount to the front assembly. Add weight and cap to the rear assembly.
Step 10: Glue (optional)
For additional rigidity, glue connections together. This will obviously prevent you breaking the rig down later.
Step 11: Paint (optional)
Mask off the screw threads and paint the complete assembly.
Step 12: Additional Damping (optional)
Add foam pad for additional damping and comfort
Step 13: Final Product
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    18 Comments
    This is an incredible project, thanks for sharing your diagrams. This would save a lot of money because video stabilizers are hundreds of dollars!
    How did you make the CAD images?
    I love this. Half of YouTube needs to love this!
    My daughter attends a media based high school. This will be a great asset for the students that won't break the school's budget. Thanks for sharing.
    The decision to "cement or not cement" (all or none) isn't binary. You can cement both sides as separate units, and then cement cross-pieces to the sides in an alternating fashion to have a rig that can be torn down with few uncemented joints, and it shouldn't come apart easily in the field.
    Good point.
    What an excellent set of instructions, keep up the good work Again, Kudos
    Awesome Ible! I made one as soon as I read your post. I made a slimmer version though. It definitely stabilized my footage by 60%. Thanks!
