Remove these ads by
Signing UpStep 1What You Need
-Small on/off switch, either push button or toggle switch
-3 AA or AAA battery holder or 3.5 Volt DC power supply
-Wire
-Solder and soldering iron/gun
-Dremel or other grinding tool
-Pliers
-Hot glue gun
as i know, it isn't nice to drive a led without a resistor...
LED resistor calculator
As a side note, it is indeed wise to use a series-parallel circuit rather than wire a whole bunch of LEDs in series. It would work fine for a while, but the lifespan of the LEDs would probably be reduced. Make series-wired clusters of just a few LEDs, each cluster with its own appropriate resistor, and then wire those clusters to your power source in a parallel circuit.
