Low Waist Baloon Frock With Waist Coat With Gather Sleeve
Published
Introduction: Low Waist Baloon Frock With Waist Coat With Gather Sleeve
this frock is made from two of my dupattas.
Step 1: Materials Required
main materials and lining materials for frock and coat
matching thread for stitching
zipper
scissors
measurig tape
Step 2: Construction of Front Side of the Waist Coat
Step 3: Construction of Back Side of the Waist Coat
Step 4: Construction of the Sleeves
Step 5: Draw the Pattern for the Back on the Cloth
Step 6: Cut the Pattern With the Seem for Stitching
cut the same on both the lining and main material
Step 7: Draw the Front Pattern on the Cloth and Cut It With the Seem
Step 8: Draw the Sleeves Pattern on the Cloth and Cut Them With the Sleem
no need of lining material for sleeves
Step 9: Make a Finishing Piece for the Collar and Front
prepare a 2.5'' inch wide lengthy strip by joining many small pieces together.
fold it in half and make small gatherings and it will look like frills.
Step 10: Start Stitching
join the sholders of lining and main material seperately
Step 11: Finishing the Front
stitch the frill on the front of main material in such a way that it covers the entire front opening including the collar.
then finish the unfinished inside of the front and collar by using the lining piece as a phasing material.
Step 12: Back Finishing
fold and finish the bottom (waist).
stitch the two darts.
Step 13: Sleeves
fold and stitch the bottom of the sleeves to finish the raw edges.
make the small gathers.
put stitches on three to four places on the gathers in lengthwise so that gathers will stay properly.
Step 14: End of the Coat
attach the sleeves to the body of the coat.
join the sides of the sleeves and coat.
Step 15: Construction of the Frock
frock has two parts.
one is the bodice part and another is the skirt part.
Step 16: Construction of the Front Part of the Bodice
Step 17: Construction of the Back Part of the Bodice
Step 18: Cutting the Materials
draw the pattern on both the main and the lining materials.
cut them with the seem for stitching.
cut some cross pieces for finishing the neck and armholes.
Step 19: Start Stitching
join the sholders of the back and the front with the lining materials.
finish the neck with the cross piece (phasing piece can also be used).
Step 20: Finish the Back Opening
stitch the zipper at the back opening.
if we want more shape we can stitch darts at the waist on the back side.
join the sides of the bodice.
Step 21: Cutting the Materials for Skirt Piece
it is a rectangular piece.
width of the skirt material is according to our desire.atleast it should be three times of the seat.
lining material's width also equal to the main material's width.
the length of the main material is
total length of the frock - seat length of the frock+5''
the length of the lining material is
length of the main material - 10''
Step 22: Start Stitching the Skirt Piece
join the side edges of the pieces seperately.
stitch the bottom of the both materials together with light gatherings on the inner side.
turn them and join the upper side with gatherings .so that the upper side matches with the bottom part of the bodice.
Step 23: Joining the Bodice and Skirt
join the skirt piece with the bodice piece.
Step 24: Small Decoration
cut long strip from the remaining material of the coat material.
make it into a thin strip by folding its lengthwise edges.
then stitch this strip on the frock at the joint of the bodice and skirt.
Step 25: The End
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
