3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low cost Halloween pop-up character
After looking at some of the available kits for making a pop-up character, they seemed of good quality but I have a lot of left over stuff in my garage and felt I could build one for less than the cost of the kit. And I offer this for the do it yourself person who may have some left over lawn sprinkler pipes as I did. This one works on compressed air and 110VAC or 12VDC to operate the air valve. If you use a remote as I did, I would go with the 110VAC. If you want to use a foot switch or step on to activate pad then I would recommend the 12VDC version.
Step 1Here is what you need:
-30" of IPs PVC pipe (this is the thin walled stuff)
-30" of Schedule 40 PVC pipe(this is the thick walled stuff)
-NPT Pneumatic Valve, from STC, PN is 2P025 -3 (this is the 110VAC you can also buy a 12VDC version if preferred), the site is: http://www.stcvalve.com/Process%20Valve.htm?gclid=COqB7_vF8pUCFRNOagodHHT1ew
-1, 1/2" PVC Cap
-1, 3/4" PVC Cap
-1, 1/2" 90deg PVC Elbow to 1/2" NPT thread
-1, 1/4" NPT Female thread air chuck (sometimes called plug)
-Various 1/4" NPT thread extension pipes and adapters
-22mm x 5 M Heat Shrink Tubing Item 98068 from Harbor Freight, http://www.harborfreightusa.com
-Garbage can
-String
-PVC Adhesive
-1/2" to 3/4" thick plywood about 2' x 2'
-2" wood screw
-1, 1/4" diameter wood dowel 5" long
-Automotive Hose clamp
-3ft lamp cord with plug on end
-Scary (Lightweight) Head such as a Halloween mask, skull, pumpkin (your choice)
-Westinghouse Wireless Remotely Operated Switch Model No. 28068 or equivalent - web site http://www.gatecomusa.com/product_info.php?products_id=2048
Optional Items:
-Sound FX Scream Unit ( bought this item at a costume shop, could not find a web source for it)
-Micro Switch - Normally Closed (when not depressed)
-1, 3/4" PVC Tee
-Threaded rod with 4 matching nuts.
-S bracket
-90 degree bracket
-Red light hooked up to a flicker circuit, see good Instructable at http://www.instructables.com/id/Haunted-Flicker-Light-Adapter/
-Fog Machine
31 comments
Sep 24, 2011. 6:48 PMleego10 says:
sick! now bury the trashcan in ur yard haha
Aug 6, 2011. 8:12 PMmkerr1 says:
Actual pneumatic cylinders can be purchased on Ebay for about $5 each if you watch. Gets rid of the whole PVC cylinder debate and just adds extra safety to the whole project.
I also STRONGLY urge people not to use PVC for cylinders even though I have seen them work flawless in a haunt for years. Over 20 years experience here.
Oct 6, 2009. 3:02 PMImproviser says:
This a very bad idea. You can check with just about any Halloween prop maker with experience (myself included with over 15 years) and they will tell you that using PVC for any pneumatic application is bad. PVC is meant to carry water under pressure, air is a totally different animal that will degrade the PVC and cause it to fail by exploding into shrapnel. PVC also fails quickly if it gets cold. For safety always use cylinders designed/rated for pneumatic applications. My pop-up props use them and they were cheap (like $12 on ebay). It's not worth the chance of causing injury to anyone.
Read the information here if you don't believe me:
http://www.phantasmechanics.com
Dec 10, 2010. 3:15 AMImproviser says:
Yes,
Unfortunately Doug Ferguson's site phantasmechanics.com has gone offline, the owner retired. He had many years of experience in prop building and is known as the creator of several props for many you see today. The link was to a good article on the hazards of PVC under air pressure and his experiences.
If you are in any business that deals with compressed air (or any gas) you will know that OSHA has severe penalties for use of PVC pipe to carry air. It is just not allowed for good reason.
Maybe this government website will help:
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
A quote from the United States Department of Labor OSHA document:
It is our position that PVC pipe shall not be used as a means of transporting compressed air. This position follows the manufacturer's own statements that PVC is unsuitable for compressed air systems. We do allow the use of certain ABS materials that are specifically designed for compressed air systems. One such product is "Duraplus" air line piping system ABS pipe. However, as in any such system, the manufacturer's specifications on acceptable pressure and temperature considerations must be followed.
Another United States Department of Labor OSHA document: Quote:
Last year, a section of PVC pipe being used for compressed air exploded 27 feet above a warehouse floor. A fragment of the pipe flew 60 feet and embedded itself in a roll of paper. Fortunately, nobody was in the area at the time.
A PVC pipe explosion in a new plant in Selah broke an employee's nose and cut his face.
PVC piping buried 3 feet underground at a Yakima manufacturing plant exploded, opening up a crater approximately 4 feet deep by 3 feet across.
Only one type of plastic pipe has been approved for use with compressed air. That pipe, Acrylonitrile-Butadiene-Styrene (ABS), is marked on the pipe as approved for compressed air supply.
PVC shatters into pieces
ABS splits lengthwise
You may be lucky is all. I would hate to be the one standing nearby when it fails. Water in PVC only transfers energy, air stores potential energy. So even at relatively low pressures, PVC can suddenly release a tremendous force.
If you rally doubt any of this, you really need to talk to the manufacturer of the PVC pipe you intend to use.
Sep 21, 2010. 3:51 PMGTechno13 says:
I have a PVC pneumatic spud gun which I like to shoot snowballs in the winter. I charge it to 100psi. :) :)
Sep 2, 2010. 11:51 PMcambigfoot says:
screaming voice fx http://www.aseanexport.com/product_info.php?cPath=2_15_18&products_id=247
Sep 1, 2010. 3:48 PMcambigfoot says:
maybe make a motion sensored light so when you walk by it it triggers the valve
Oct 19, 2009. 8:09 PMyour dog says:
Nice!
for mine i used halloween skull masks. i have a 120 PSi going into 2 tubes. i will add a picture soon.
Oct 16, 2009. 8:55 PMEPL says:
Awesome!!
Oct 8, 2009. 4:58 AMThomasR142 says:
 i tip my hat to you sir
very well done!
so simple so great
deffs makein' this one
Oct 6, 2009. 6:37 AMfrollard says:
Overkill: Arduino can add a really customizable automation to provide one-shot-delay functionality so that you can use a mat to set it off, but it won't go off more than once a minute.
More work, but cheaper:
A 555 timer can also be configured to do just this: Configure it in monostable mode. When its 'stable' it activates a transistor that 'allows' the foot pad signal to hit the valve. Then the timer portion locks out the switch for your choice of time. A second 555 timer (or a 556) can be used to keep the valve open for x time (about a second) after the activation. so its not just a quick burst then nothing.
http://www.bowdenshobbycircuits.info/page9.htm#mono.gif explains using a 555 or some digital circuitry to achieve this trick.
Oct 7, 2009. 1:29 AMfrollard says:
Good to hear that! Again, wonderful project!
Oct 5, 2009. 11:11 AMnolte919 says:
Could you use a standard sprinkler valve found at any hardware store? At my local Home Depot they are $13.15 and a 25v transformer from Radio Shack (according to their online catalog) is $6.29. Which would make a valve cost $20, no shipping, and found completely locally. If anyone's curious that sprinkler valve sold at Home Depot take 24VAC, 60Hz; they pull 400 mA inrush and 200 mA continuous. All standard sprinkler valves take the same 24VAC voltage and I think current requirements are similar.
Oct 6, 2009. 7:16 AMnolte919 says:
Also, the spud gun guys have ways of modifying sprinkler valves so they release all their air when a firing tube releases its air. This Instructable recommends this and this site for such modifications.
Oct 6, 2009. 6:29 AMfrollard says:
I use sprinkler valves for upwards of 100psi for just this type of application - easy peasy!
edit: I use the 12vdc models, same valve different solenoid from home depot.
Oct 6, 2009. 6:28 AMfrollard says:
I did exactly the same in our candy dish with a door-closer pneumatic piston. Simply glue/thread a pipe into the 'adjustment screw' hole - and you've got a self returning *with bleed valve on the source line* piston for cheap. I love your design with the exception of that it relies on a piece of string to prevent an 'international incident'...perhaps something a little more substantial?
Great stuff! 5 from me!
Note - ours is small, and mounted IN the large wicker candy bowl. When someone reaches in for candy, we activate it, scaring the poop out of them.
Oct 5, 2009. 6:47 PMdesco says:
Use a bike pump. It's not much more expensive than building it yourself, a whole lot less hassle, and it'll work much better-- it doesn't leak. You may have to open it and take out a one-way valve. It's usually a loose rubber ball or flap near where the hose goes into the cylinder, and they're usually pretty easy to remove. My father and I made a half dozen using PVC, and we've since converted everything to bike pumps and door openers and gas lifters. Except the 6ft piston that comes out of the sewer, but they don't make bike pumps much longer than 2 1/2 ft.
Oct 5, 2009. 8:43 PMdesco says:
Only difference is our PVC pistons had the inner pipe the moving one, and the outer was the cylinder. We glued a middle-sized ring of PVC to the top of the cylinder and the bottom of the piston and sanded it until it just barely fit (instead of using rubber) and used graphite lubricant. No tether... which eventually the impact between the cylinder and the piston caused the glue to fail, and our skull went flying 50 ft out of the barrel. (Probably had the pressure too high too) Since then we started using weed-whacker line for tehters because it's incredibly strong and slightly elastic, so it didn't stress the PVC joints. But eventually we switched to gas lifters and bike pumps because they're pre-made and don't leak, so we don't lose air by leaving them extended. The problem with this is you NEED an exhausting solenoid, or it'll never come back down. Those are harder to find-- new they're very expensive. We ripped ours out of old dishwashers. We started this 15 years ago, so we've gotten a lot of experience on what works and what doesn't. Plus there's already a lot of information on the internet--although "back in the day" it was all newsgroups. I'm not saying your well written Instructable isn't valuable... It's sad a lot of those discussion groups' information we used is probably gone.
Oct 5, 2009. 6:11 PMppatches24 says:
dude sweeet jod love it
Oct 4, 2009. 6:38 PMPadlock says:
From stc9.com, how much did they charge you for shipping? I want to submit my order, but am afraid that they'll overcharge me for shipping the piece.
Oct 5, 2009. 5:24 PMPadlock says:
That's quite a plume you get when the head goes back down.
Oct 4, 2009. 5:05 PMMACKattacksnipe says:
im going to hide mine in the bushes
Oct 4, 2009. 9:28 AMking_zilla says:
We have place over here in Idaho that's called the haunted world and they have one of these by the gates. Gets me every time. = ]
Great Job
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Back Roads
