3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low cost Halloween pop-up character
Step 8Assemble the pneumatic lift assembly
Glue the PVC into the elbow. Place the assembly up against the V-groove of the Strong Back (wooden dowel) with the elbow down against the plywood. Place the Spacer you made in step 6 between the PVC and the Strong Back's groove near the top of the groove. Glue this into place. Now place the Automotive Clamp over the PVC and the Strong Back. Locate it way between the Elbow and the Spacer then tighten. Slip the PVC over the PVC and check the top and verify the 2 are almost level. If not, trim one or the other until they are. Then glue the PVC Cap on the PVC. If you are the anxious type, the system can now be tested, but be warned the PVC will launch like a rocket (hey maybe that is another Instuctable?).
2 comments
Oct 6, 2009. 3:02 PMImproviser says:
This a very bad idea. You can check with just about any Halloween prop maker with experience (myself included with over 15 years) and they will tell you that using PVC for any pneumatic application is bad. PVC is meant to carry water under pressure, air is a totally different animal that will degrade the PVC and cause it to fail by exploding into shrapnel. PVC also fails quickly if it gets cold. For safety always use cylinders designed/rated for pneumatic applications. My pop-up props use them and they were cheap (like $12 on ebay). It's not worth the chance of causing injury to anyone.
Read the information here if you don't believe me:
http://www.phantasmechanics.com
Dec 10, 2010. 3:15 AMImproviser says:
Yes,
Unfortunately Doug Ferguson's site phantasmechanics.com has gone offline, the owner retired. He had many years of experience in prop building and is known as the creator of several props for many you see today. The link was to a good article on the hazards of PVC under air pressure and his experiences.
If you are in any business that deals with compressed air (or any gas) you will know that OSHA has severe penalties for use of PVC pipe to carry air. It is just not allowed for good reason.
Maybe this government website will help:
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
A quote from the United States Department of Labor OSHA document:
It is our position that PVC pipe shall not be used as a means of transporting compressed air. This position follows the manufacturer's own statements that PVC is unsuitable for compressed air systems. We do allow the use of certain ABS materials that are specifically designed for compressed air systems. One such product is "Duraplus" air line piping system ABS pipe. However, as in any such system, the manufacturer's specifications on acceptable pressure and temperature considerations must be followed.
Another United States Department of Labor OSHA document: Quote:
Last year, a section of PVC pipe being used for compressed air exploded 27 feet above a warehouse floor. A fragment of the pipe flew 60 feet and embedded itself in a roll of paper. Fortunately, nobody was in the area at the time.
A PVC pipe explosion in a new plant in Selah broke an employee's nose and cut his face.
PVC piping buried 3 feet underground at a Yakima manufacturing plant exploded, opening up a crater approximately 4 feet deep by 3 feet across.
Only one type of plastic pipe has been approved for use with compressed air. That pipe, Acrylonitrile-Butadiene-Styrene (ABS), is marked on the pipe as approved for compressed air supply.
PVC shatters into pieces
ABS splits lengthwise
You may be lucky is all. I would hate to be the one standing nearby when it fails. Water in PVC only transfers energy, air stores potential energy. So even at relatively low pressures, PVC can suddenly release a tremendous force.
If you rally doubt any of this, you really need to talk to the manufacturer of the PVC pipe you intend to use.
Sep 21, 2010. 3:51 PMGTechno13 says:
I have a PVC pneumatic spud gun which I like to shoot snowballs in the winter. I charge it to 100psi. :) :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Back Roads
