Introduction: Low-cost ROBOT Gripper Hand
Picture of Low-cost ROBOT Gripper Hand
This is a GRIPPER hand made from only 2 servo motors & very common hardware items that could be bought easily.This is a home made project & I hope you like it!
Step 1: Find the Parts
To do this home project you will need the following item
  • Small POLYCARBONATE sheet.(I used leftover stuff )
  • NUTS & BOLTS and matching WASHERS (I used 2 sizes of it)
  • Different colored wires (I used old CAT 5 cable wires & normal electrical wires)
  • SUPER-GLUE
  • 2 nos square small ERASERS
  • LED bulbs (2 colors) & 1k ohm (1/4 watt) resistors.
  • OLD used tooth brushes (for the ARMS)
  • TOOLS - ( Drill / screwdrivers / soldering iron & lead etc / blades / saw etc)
  • Arduino UNO card or compatible board & PC to program it with. (as I will show you a mega 2560 can also be used as well)
  • 5V POWER supply (3 Amps)
  • plastic wire ties
Optional Items - (NOT mandatory at all)
1) small CCTV camera module - (I connected it to a TV Capture card to get a close up view of the ARM in action)
Step 2: Assembley
Use the picture as a guide to assemble the hand & wire it to a 5V DC PSU & a UNO. The code to open & close the hand can be written using Arduino's Stepper library!
DIY Hacks and How Tos (author)2016-03-26
Cool robot grippers.
Thanks.It's just something I wanted to do and see for my self.Had a lot of fun building it!
About This Instructable
252views
7favorites
License:
Bio: Fan of electronics / physics based things......
More by Afzal cassim:Low-cost ROBOT Gripper Hand
Add instructable to:
