3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low-cost Spherical Speaker Array
Step 6Cut and adjust the speaker holes
Again with the dremel cutting bit, cut along the lines you drew in step 5. There is quite a bit of inaccuracy introduced by trying to draw a flat template onto a curved surface. The first hole you cut is going to be too small. Test fit the speaker, and cut out more material where it rubs against the speaker. Don't worry about ragged edges, they will be covered by the speaker flange.
NB: This might be a better time to do step 13.
1 comment
Apr 25, 2007. 8:50 AMmje says:
Actually, any speaker will radiate omnidirectionally at frequencies whose wavelength is greater than 4x the diameter of the speaker. So 4" speakers will radiate omnidirectionally at all frequencies below 2.5KHz. Stil, an interesting project, and one that would make a pair of neat computer speakers.
Apr 25, 2007. 3:55 PMmje says:
Sound travels at 1000m/s, so an 850Hz tone has a wavelength of 1000/850, or roughly 1.18m. A quarter wave is .295m, or 11.6 inches. You may have made a units conversion error. But yes, it's not a bad idea to do this with smaller speakers and use a single woofer. And yes, you can't really localize a sound with a wavelength that's large compared to the distance between your ears, as you can't detect the phase difference.
Apr 25, 2007. 7:29 PMmje says:
BTW, the idea of a polyhedral or spherical speaker enclosure is an old one. There have been commercial cabs like this going back to at least the 60s. One of the the best way to make a cabinet "disappear" and appear as a point source is to get rid of early reflections- those coming off the face of the cabinet. One way of doing this is to caver the area surrounding the speaker cone with something that absorbs sound, like heavy felt.
Apr 25, 2007. 7:23 PMmje says:
You're right, I was wrong, what was I thinking? Mea culpa.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:mzed
