3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low cost tank-tough workbench
Step 4Finish the frame
Finish the frame
The next step is to attach the front of the bench. Cut a 2x4 to length and then screw it into the end pieces and the cross braces using 3" screws. With the front attached, start screwing the diagonal braces in place between the end and cross pieces and the front lumber. When attaching the diagonal braces to the front, you may want to use 2.5" screws so you don't pop through the front and leave sharp tips to cut you. See pics to get an idea.
With the frame fully triangulated, cut some scraps to increase the load bearing capacity of your bench. The idea here is to cut a diagonal that will extend down from the cross braces at an angle and anchor to the wall. See pics below. Toenail the bottom part of the 2x4 into the wall. The screws are to hold the brace in position, the real strength is that this brace is loaded in compression so you want to be sure it fits snugly between the top and the wall. Use your level to make sure you don't over do it and tip the top of the bench in towards the wall.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:jmengel
