Step 6Anchor the leg(s)
You can also see in the pics that the vertical leg is now two 2x4s thick. Using the level on the top of the bench I cut a section of 2x4 that snugly fit between the bottom stud frame of the bench and the floor while keeping the top level. This vertical support will bear a lot of the bench abuse so cut it square and snug.
Now that the hole is drilled and the anchor set in the concrete, take your angle bracket and bolt it to the concrete anchor. Then screw the bracket to the bench leg. Repeat this process for any other legs you may have. Viola, you now have a super tough workbench that is anchored to your walls and your floor that will withstand anything you can throw at it. If the bench collapses, so will the building.
You can now attach any auxiliary items such as vices and other things you may want for your bench. Try to attach you most brutal item right over the concrete anchored leg. In my case, the 5' metal vice would take the most pounding, so it is mounted right over the leg. Happy hammering!
Add Comment
