Introduction: Low Power Usage USB Speakers - Ideal for Raspberry Pi
I am in the middle of building a raspberry pi bartop gaming cabinet that runs off battery. One of the issues I ran into was that the 7" monitor I was using had no speakers, and other speakers took up too much power from the battery to run the PI.
Step 1: Parts and Why to Make?
This is a small speaker that uses under 500 mah for its current. It can be played at full volume off a simple USB 2.0 port. My arcade project is fully powered by a 2.1A 5v battery, so I needed a speaker with a low output.
Parts and Cost
ILUV speaker - 5$
I originally bought this at 5 below last year, and it only ran off of 2 AA batteries. I think ILUV has discontinued selling it, so only some 5 belows will have it. If not, find it on eBay.
any kind of usb cable - 1$
I used an old camera cord, but dollar tree has usb cables for 1$
Step 2: Tools and Skills Needed
This project requires beginner skills in soldering, and knowledge of Knife work and glue gunning
you need
A Exacto Knife or Stanley Hobby Knife
A soldering iron, type of solder doesent matter.
a hot glue gun
I also used a flat head screw driver to pry up the battery casing
Step 3: Pull Up the Battery Pack and Solder
first thing to do is pull up the battery pack. I used some elbow grease, a flat head screw driver, and my knife and after mabye 10 min I got the pack free.
Once you have the battery case free, twist it around so you can see the back of the case you put the batteries in. There should be 2 solder spots with cables running out of them.
WARNING - I was unable to tell what was positive and what was negative due to no labels, and connected it wrong twice. I shorted out my connection, but thankfully I was using a battery pack instead of a wall socket. The battery pack came back to life after I plugged it into a wall socket, but you can electrocute yourself if you are using a wall socket.
Figure out which solder spot is which on the case. Then use your knife to cut the usb cable in half, and strip down the wires (wire stripper or knife) so you have access to the positive and negative wires on the Male usb port side. If you have data cables ( usually green and white ) clip them off.
solder the positive wire to the positive solder spot, and vice versa with the negative.
Step 4: Protect the Connections
now that our soldering is done, put some kind of protection on those connections! I put hot glue around the solder spots, and hot glued the cord down at the base to relieve the tensions from the soldering. I also wrapped tape around the wire stubs to stop the red and black wires from bumping and shorting out.
Step 5: TEST IT. YAYAY
Moment of truth. Plug the Male usb port into a power source. If the battery indicator light comes on (the red light) then it should work fine.
Step 6: Thanks for Checking This Out!
It's always cool to see people inspired by you. I am only 13, and My first instrustable ( and my only real one ) on how to build a raspberry pi laptop was a hit with all you viewers. If you happen to build this project, PLEASE comment a photo to show me, and even if you don't, a comment saying somthing good, bad, or helpful is nice to see!
I will be posting and instructable of my mini low - budget arcade machine featuring these speakers, so if you subscribe, you will be able to see it!
Thanks for looking!
2 Comments
I was just debating on buying thos at 5 and below because they had them on sale for 3.50. How do they sound?
they sound good and have a high volume for the price. I say go for it
