3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Low profile linear LED array
Got a dark closet with no room for a light? This Instructable presents one way to solve the problem: a low profile array of high intensity LEDs mounted in aluminum channel. Simple, effective, cheaper and better than what you can buy out in the market currently. I wanted a 60 inch span outputting a total of around 1000 lumens. There were a few options out there, but none fit the bill. Also, none allowed me to design and build my own light and live to tell the tale.
I looked into buying Elara strips but since they are $20 apiece I would need to spend $100 to span my 5 foot wide closet and still need to buy and mount to a heatsink and get a power supply. Additionally, the warm white Elara strips are about 130 lumens per foot which would give only 650 lumens for the whole array and at pretty poor efficiency (<50 lumens per Watt before power supply losses). The more powerful Luxstrip II strips output in the neighborhood of 500 lumens per foot at 350mA which is too much for my application and at $45 per foot would be even more painful on the wallet. A heatsink and power supply are also required.
After careful consideration, I determined that purchasing single high efficiency Cree XPG warm white LEDs on star boards and mounting them to a heatsink and providing a constant current driver would be more cost effective and yield superior results.
Step 1Materials
Materials
This build is pretty basic. The light fixture is the heat sink, and the rest is just LEDs, mounting, driver, and wiring. I'm still working on a diffuser but after having the light installed for a while I kind of like the look of the bare LEDs. Total cost was about $100. A note on the driver, this is a small and cheap driver but it is not UL listed, is not dimmable, and generates some interference in my experience. So if you are trying to listen to a far off radio station, turn this light off.
Materials:
8 feet of 3/4" wide by 1/8" thick aluminum channel from McMaster Carr ($13.70)
11 Indus star boards with warm white Cree XPG LED ($6.05 x 11 = $66.55)
16W 320mA constant current LED driver ($7.60)
22 4-40 screws
Suitable wire
Thermal compound
Heat shrink tubing
Tools:
Drill
Drill bit and tap for 4-40 threads
Soldering iron
Solder
Screwdriver
Hot glue gun
Aviation snips
File
Multimeter
4 comments
Dec 25, 2011. 4:53 PMHesperolinon says:
Great project and great instructions/post! Thanks for all of the detail and clarity. I have two questions for you. I want to adapt this project for use as a livingroom light bar, placed along a mantlepiece, in which the lights shine upwards. Around each LED I'll position a "shade" to capture the light and channel it upwards. Anyhow...was wondering a) how many of these LED's you can wire together and power off of the plug-in adapter/converter you used in this project, and b) whether I could substitute in a higher-power LED? Thanks for your help!
Jan 1, 2012. 12:02 PMHesperolinon says:
Thank you, sir, for that response to my questions and explanation of options. I'm an electrical neophyte and so I wanted to ask for clarification before I move forward with my project. The LEDs will be positioned at 3-foot increments along the mantlepiece, shining upward and ultimately positioned behind a shade of some sort, which should prevent retinal pain. I'll be mindful of heat dissipation but from your response I gather that the U-channel will be a sufficient heat sink if the LEDs are spaced this far apart. So to be clear, I can wire up 10 warm white Cree XPG LEDs using the 670mA 36W driver you pointed me to and the instructions in your post, and the array will produce 2500 lumens total. Again, based on your response it sounds like this could be "blinding," but a single 60W incandescent bulb should put out about 800 lumens, so this doesn't seem like a ton of light. Can you clarify? Thanks again so much for your help!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:jmengel
