A few months ago a friend of mine -car mechanical at profession- told me that he had problem with some car sensors. He couldn't check, with a simple multimeter, if a sensor was working properly. I advised him to buy a LCD oscilloscope instead of a normal oscilloscope, because of its small size. The use of an oscilloscope is very helpful because you can see the waveform that is produced by a "healthy" in-circuit-sensor* and you can compare it with the waveform of a "suspect" in-circuit-sensor.
After that, he told me that this oscilloscope costs a "fortune" for him as he has a small car service shop. I offered to help him by designing and constructing a small, cheap and workable LCD oscilloscope for him.
*in-circuit-sensor is the sensor which is connected on a board (PCB) or it's connected somewhere in the car. It's not a disconnected sensor.
You can download the source code, hex, schematic diagram,PCB and picture of the circuit .
Remove these ads by
Signing UpStep 1Selecting the components
Will it work at 8mhz?
That would be a good idea but there is not free time for that!
Yes, but you must change the crystal frequency in the source code and re-compile it. The circuit will run in low performance.
thanks for your perfect site.
I need some explanation for the structure of the c file of this project.could you help me please?
if you mail me that i will be pleased.
this is my email address:matin_lili@yahoo.com
- Now, indications such as voltage and frequency are displayed on LCD.
- A small increment of sampling rate has been made too.
Regards
but this one is very good.....
where can i get the lcd....its not available here at my place...
i can make online shopping..
can anybody who made this project, send me few links for online shopping
what will be the cost of the LCD?
what is ks0108...do i need to buy this controller or simply lcd?
make my doubt clear....
http://www.seeedstudio.com/depot/digital-storage-oscilloscope-with-panels-p-167.html
there is also a kit but it needs smd soldering.
http://i39.tinypic.com/30vk45l.jpg
It turns out i didn't need to use an inverter, your screen is the same as mine!
Although I have a problem: I'm using software 1.01 and I can't use the time/div buttons (left and right). Do you know a solution?
Heres the datasheet
http://www.artronic.pl/o_produkcie.php?id=612
http://mog123123.googlepages.com/glcd2.c
Besides I see that the "signal wire" of the probe connector (K1) is soldered to both ground(0V) and Capacitor (C2) why is that?
http://www.serasidis.gr/circuits/AVR_oscilloscope/avr_oscilloscope.htm
