Lucina / Chrom Sword (3D Printed)
2,016
52
Posted
Introduction: Lucina / Chrom Sword (3D Printed)
This is the sword Lucina and Chrom used from the video game Fire Emblem. It was 3D printed in natural PLA and then painted. I designed the model in autodesk inventor based on reference drawings I found online and using the book 'Knights of Iris' showing artwork from the game. I changed a few things on the falchion to make it more to my liking.
To print the sword, I cut the design in half (horizontal plane) and then in 3 pieces length-wise since it is a 40" sword and I have a 16" wide bed. At the interface between segments, I made V-slices to the stl so that when I go to solder and heat-weld the PLA pieces together, they have the most strength. This worked well for my Ike sword that I printed in a similar way. The whole sword took 2 days to print (multiple pieces throughout, so some dead time) and is about 650g in material.
Lucina / Chrom Sword files can be found on thingiverse:971540.
Step 1: Assembly
I didn't document this well while I did it but the idea is pretty simple. I used a soldering iron and hot air re-work gun to melt the pieces together. It is worth practicing on scrap pieces first because it is really easy to get the plastic so soft that it collapses into the support structure and ruins the look of the piece.
I would first hold the pieces flat and flush with each other and then drag a soldering iron tip through the interfacial seam to weld them together. Then I touched up the piece with the air re-work gun using smoothed aluminum foil on my fingers to smooth out edges (gently!).
The sword was designed with 'V' shaped ends on each piece so that they would fit together with more surface area. Square ends would have allowed pieces to be printed larger but would have had the downside of weaker welds.
Step 2: Painting
To paint PLA, I always use a clear primer spray paint (or any color). I then painted with acrylic paints. I don't really like to paint much so I didn't spend a lot of time trying to texturize or mix colors at all. I just used what I had sitting around.
There is a picture of my Ike sword as well :) The Ike sword files were downloaded from thingiverse:633144
My Lucina / Chrom files can be found on thingiverse:971540 as well. I know the files are rather large for most desktop printers so you may need to use Netfabb / MeshLab to rip them up so that they fit on your bed. Both of these software have a free version that is all you need for this process.
If you really want one and aren't able to make it yourself, I can print more if you PM me.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
