Lucky Star Beads
Introduction: Lucky Star Beads
In this instructable I'm going to show you how to make beads out of these really cute lucky stars. There are a lot of wayts to do it after you folded the star, but this is WAY easier. I hope you like it!
Giveaway in step 7!!!     CLOSED
Step 1: What Do You Need
To make lucky star beads you will need
- paper 1/16 A4
- paperclip
To add the lucky star beads to cord you will need
- wire
Step 2: Starting
First you will nee dto make the same 'knot' as by normal lucky stars. In the prictures is shwn how to do this.
After making the knot we are going to use the paperclip. Bend it straight. Put it through the base so it is in two of the corners.
Step 3: Wrapping
Now you need to wrap the paper around the base. You just wrap and wrap and the paperclip stays in it's position. Tuck the end in.
Step 4: Pop-up
Take the base/paperclip between your fingers and press at the middle of a side to make it pop up. Repeat this for every side.
Step 5: Remove the Paperclip
Now you can just take out the paperclip. When you look closely, you'll see the hole.
Step 6: Get It on the String
To get your beads on a string, you can best take a piece of wire and make a 'needle' . Because you can flatten it a bit, it will fit through the bead.
Step 7: What Can You Make?
What have you made with these beads?
The first three people who send me a pic of what they made with it will get a 3 month pr-membership and a patch designed by me!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    I used to always have trouble making mine pop up til a friend showed me a trick. You can gently roll the side of a pen on each edge of the star to make it start to pop, then finish it with your fingers.
    That is such a better way of making these stars. Thank you so much.
    Woohoo! I finished my birthday gift! Thank you for the inspiring instructable!
    I made these earrings and a matching necklace charm. I should have colored it in before folding it, though.
    they are lovely!!! Check your inbox for your gifts
