3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Luminous Mushroom Night Light
I was intrigued by those mushroom lamps by a Japanese artist.  I didn't like the on/off button, though, and I wasn't thrilled about the prospect of making mushrooms out of glass.
Here's my version, using stuff I had on hand.
Unfortunately, we didn't have a suitable solar panel and my husband wasn't up for running to the local supplier for one, so I have to wait a bit before it's completely finished to my liking.  I designed the shape so the small solar panel can rest on the back at an angle and charge during the day if one leaves it in a sunny windowsill.
I wanted the mushrooms to resemble the real luminous mushrooms and glow for awhile after it was turned off.
Step 1Prepare the log
Prepare the log
I was originally going to use part of a birch branch I cut from our tree (it had been partly rotted).  Once I started sawing the rotten part off, two spiders and an earwig crawled out and I lost my nerve.  I considered my other options.
A smooth, decaying stick I found in the strawberry bed seemed aesthetically pleasing... but all the cracks almost guaranteed lots of bugs.
The maple branch I'd removed from our tree a few weeks ago was almost certain to have very few things that might crawl out and bite me, but it just wasn't very interesting to look at.
Finally, I decided on the root end of some evergreen bushes I recently ripped up.  I didn't see any holes where bugs might be hiding, and it was definitely interesting to look at.  I washed it with the hose, broke off the extra branches, and dried it in the oven at 200 degrees for a couple hours.  That way, any bugs would hopefully die.
I then drilled holes where I thought mushrooms should go.
I decided to put the wiring etc in the back, rather than hollowing out part of the log.  The solar panel would have to be visible, anyway.
101 comments
1-40 of 101next »
May 11, 2012. 6:36 AMsiskk says:
Love the idea...where in the heck do you get the led lights and all the know how to hook up wires??? I don't have a tech savy hubby but I think I could figure it out if I had some direction.
Dec 3, 2011. 12:30 PMfsfshsyhh says:
Can you help me please? i want to have LED lamps in serial
power supply 3V
forward voltage 3.2-3.4
20mA
How many leds can i light up with 3V? Do i need a resistor for that, and how many OHM? Im a really beginner and i need help.
Dec 3, 2011. 10:58 PMsrhadaham says:
I also don't know a whole lot about this, but i find this website most helpful
http://led.linear1.org/led.wiz
just plug in the specs for your lights and power source and it will give you what you need to know
Dec 3, 2011. 10:15 AMdb'alexander says:
Well done, I love the combination of wood, plastic and electronics. I am usually more verbose, but I am hungry and somewhat amazed at how good this looks.
Dec 2, 2011. 12:12 PMFrozenIce says:
wow dude, these ar saaweeet :D
Nov 29, 2011. 10:02 PMuna_amor says:
Oh my word. This is so enchanting. It makes me calm. It reminds me of the iPad game "Spirits". I can imagine placing a little music box inside of it somewhere. It would make a cool night light for kids. Thank you for this great project.
Nov 28, 2011. 6:34 PMshortone says:
http://www.instructables.com/id/Gifts-For-Guys/
Put you in my gift guide for guys! Just thought I'd let you know :)
Apr 10, 2011. 4:53 PMdmadru says:
I'm Confused. Where Exactly Are The LEDs Located And Where Are The Wires That Are Connected To The LEDs Are? It Looks Fantastic By The Way!
Apr 11, 2011. 2:37 PMdmadru says:
I Understand That But Where In The Mushroom Caps. Is The Clay Slightly Translucent?
Nov 28, 2011. 11:20 AMkennan says:
I can answer this. Yeah, Sculpey in the lighter colors is somewhat translucent, especially at low thicknesses.
Nov 28, 2011. 3:22 PMdmadru says:
Thanks
Oct 31, 2011. 6:31 AMTinkering_Pirate says:
I absolutely love this. I am slowly turning my office into a "wizard's study" and it seems to me that a log with luminescent mushroom growing on it would fit in quite well with the theme!
Sep 10, 2010. 9:03 PMFoo_Plinger says:
I have a question....just started breadboarding this tonight, using a solar light I bought at Lowes (3.99), it is a single led, with a single battery, and a photocell to turn it on at night. Picked up a telephone battery pack (3 AA's) to power 6 led's. I have that all hooked up with resistors (1/4 watt), and everything looks good, EXCEPT, the photocell won't turn the lights off/on. If I have the one led attached, the photocell turns it on/off according to the light. Once I hook up the 6 led's, it no longer turns them off. What gives? Is it the increased power, or the increased draw? Anyone have ideas to check?
Thanks.
Oct 16, 2011. 4:00 PMBlueberry says:
Right. The trouble with using a photo cell is that it is itself a resistor. Each LED requires a "forward voltage" somewhere between 2 and 3.5 volts. When electricity passes though it, it consumes some amount of voltage as well, using that energy to create light. Resistors are used with LEDs to restrict how much energy passes through them, so they don't overheat when connected to a power source higher than their forward voltage. When you use more LEDs, the photocell is apparently providing enough resistance to stop them from each being able to receive their forward voltage. One way around this would be to use a transistor as an electronic switch. It can take in the signal from a photo cell, and switch a much larger power supply to the LEDs without adding very much resistance at all, so you can still use normal online LED resistor calculators.
To use a transistor, you would want to connect the LEDs and photo cell to the positive end of your power supply, then connect the negative end of your LED array (including any resistors) to the 'collector' wire of the transistor, and the photo cell in series with a resistor around 5-10kohm, connected to the transistor's base, with a high value resistor like 1mohm connecting from the base to the negative of your power supply, as well as the emitter wire from the transistor also connected to the power supply negative. A circuit like that should work with NPN transistors like the common 2n2222 a which are available for less than a cent in large quantities, so should be cheaply available anywhere.
Oct 18, 2011. 7:07 AMFoo_Plinger says:
Your reply will help me out I think, but I wanted to point out that my problem is not that the LED's won't turn ON, it's that they won't turn OFF. With just one LED the photocell works as expected, with 6 they stay on constantly, regardless of how much light the photocell is receiving.
Oct 18, 2011. 5:10 PMBlueberry says:
Could you explain how you have things wired up now?
Sep 8, 2010. 5:55 AMinstructamum says:
red red brown on a tan body is probably a 220 ohm resistor (red is 2, the third band, brown is *10, so 22*10=220 ohm).
http://www.csgnetwork.com/resistcolcalc.html
The tan colour means it is a carbon resistor. these are the most common and cheapest to buy.
3 volts from two AAA would barely power most -white- LEDs, even without a resistor.
Usually White LEDs require a minimum of 3.2 volts but some won't switch on till 3.5 volts. So if anyone has problems, use a third battery.
http://led.linear1.org/1led.wiz
I really like the look of this project. thanks for the instructable.
Oct 7, 2011. 10:28 AMgreintsma says:
What???, I've disassembled so many products with the same parts(especially little solar garden lights) and they ALL used two AAs which also produces a combined 3 volts and they use a variety of LEDs of different types/sizes. ???
They do have slightly more complicated circuits, is there a "voltage upstepper" or whatever that component is called if such a thing exists?
Oct 8, 2011. 3:11 PMinstructamum says:
They would almost have to have a dc-dc converter.
Rechargable AA batteries only hold 1.2v. For a total of 2.4v --- White LEDs are on average 3.5v devices.
Ref: http://en.wikipedia.org/wiki/Light-emitting_diode
Here is a simple tutorial for making a dc-dc booster- ideal for LEDs.
http://www.evilmadscientist.com/article.php/joulethief
I've made many of these, it's a fun little project.
The nocturnal circuit that turns on the lights is really nifty too. This is a very relyable and efficient one, you can replace the 1F cap with three rechargable batteries. http://www.beam-wiki.org/wiki/Wilf%27s_Pummer
Enjoy!
Feb 12, 2011. 4:54 PMictrewel says:
Came across your article, so I decided to do one of my own. Thanks for the inspiration! Not as elaborate as yours, but plans are there for the future.
Oct 3, 2011. 9:25 PMhhamilton2 says:
Yours is darling!!
Feb 27, 2011. 1:28 PMAlex Ribeiro says:
Nice work!
Aug 23, 2011. 10:39 PMPatchIsCooking says:
I've never used Sculpey before. How does it fair against the weather? These would be great to have lining my walkway outside. Electronics aside, how do they hold up against wind, rain, and sun?
Aug 23, 2011. 4:59 PMinstruct39 says:
very cool! great instructable, quite clear and detailed
Aug 23, 2011. 4:36 PMilpug says:
I want to make several of these in my room.
Aug 23, 2011. 9:47 AMllepisto says:
I love this, I like to know how do I find or to make mushroom sculpey polymer clay that I am first time to learn to and want make this that my really favorite glow mushrooms.
Aug 20, 2011. 6:33 PMMia bea says:
This is wonderful! I have the perfect piece of wood to use for this and some polymer clay! The only thing is I need to learn how to wire LEDs since I've never used them before- but I'm sure there are plenty of instructables on just that! I was wondering if there was a way to have more than one LED light affixed so I could have say, green and black light; would I have to put more wires through them and if one burns out would I be able to remove the cap without breaking it or should I find a different way to affix them?
Feb 11, 2011. 11:56 AMalitlcrzyart says:
Can you suggest a solar panel to purchase and a site to buy it from? I have been confused by what volts I need and have seen solar cells and panels for $1.50 to $37.00. I love the idea but I am not sure what to buy to make it work correctly. Thank you!
Aug 11, 2011. 10:00 AMNasubi77 says:
If you can find a set of solar yard lights at a yard sale or something, you can dissect it and use the solar panel from it! A lot of people will just toss the cheap ones out when they stop working, but it's rarely the solar panel which has gone bad.
Jul 31, 2011. 11:38 AMPippikins says:
oh! It's beautiful! i don't quite understand the wiring lights and placement aspect of it, but I'm sure I'll figure something out
Jul 25, 2011. 5:35 PMiamadam says:
I was inspired by this. I did not have the translucent clay though. I used green LED and under-lit the caps. I used the 5V power from an Arduino. I will have to figure out something more permanent though. Thanks for the awesome idea. I do plan on trying some more ideas. Especially since the Michael's craft store near me has a 50% off polymer clays sale going on.
Jul 6, 2011. 6:24 AMporcupinemamma says:
Magical! You've made many fairies and elves happy too! 10/10. 100%!!!!
Jun 27, 2011. 8:37 PMRedline_lover says:
This is definitely the most beautiful lamp on instructables, and i dont even like mushrooms! Great job. And i love the shiny dust on top. I've been thinking about jumping into a electric project and i think this just decided it for me. :3 Thanks.
May 15, 2011. 5:45 AMCyclonicNinja says:
I'm gonna have to make green mushrooms for a Fallout themed room, Nice work!!
Apr 17, 2011. 12:11 PMEvieErmine says:
WOW...beautiful job. If I knew anything about wiring things I would try it lol.
Mar 3, 2011. 11:18 AMfire1888 says:
Very creative and very unique, great job! :)
Jan 4, 2011. 8:54 AMchuckr44 says:
That. Is. Awesome.
And simple enough even I could do it.
Sep 13, 2010. 2:36 PMzascecs says:
magic mushrooms...
1-40 of 101next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
270
Author:supersoftdrink(my etsy store)
I took over my husband's Instructables login last year to make a couple instructables for two contests. He was only using it to browse stuff, anyway. I have a different and sillier name elsewhere on...
more »
