loading
loading
Picture of Luminous Mushroom Night Light
I was intrigued by those mushroom lamps by a Japanese artist.  I didn't like the on/off button, though, and I wasn't thrilled about the prospect of making mushrooms out of glass.
Here's my version, using stuff I had on hand.
Unfortunately, we didn't have a suitable solar panel and my husband wasn't up for running to the local supplier for one, so I have to wait a bit before it's completely finished to my liking.  I designed the shape so the small solar panel can rest on the back at an angle and charge during the day if one leaves it in a sunny windowsill.
I wanted the mushrooms to resemble the real luminous mushrooms and glow for awhile after it was turned off.
Step 1: Prepare the log
Picture of Prepare the log
I was originally going to use part of a birch branch I cut from our tree (it had been partly rotted).  Once I started sawing the rotten part off, two spiders and an earwig crawled out and I lost my nerve.  I considered my other options.
A smooth, decaying stick I found in the strawberry bed seemed aesthetically pleasing... but all the cracks almost guaranteed lots of bugs.
The maple branch I'd removed from our tree a few weeks ago was almost certain to have very few things that might crawl out and bite me, but it just wasn't very interesting to look at.
Finally, I decided on the root end of some evergreen bushes I recently ripped up.  I didn't see any holes where bugs might be hiding, and it was definitely interesting to look at.  I washed it with the hose, broke off the extra branches, and dried it in the oven at 200 degrees for a couple hours.  That way, any bugs would hopefully die.
I then drilled holes where I thought mushrooms should go.
I decided to put the wiring etc in the back, rather than hollowing out part of the log.  The solar panel would have to be visible, anyway.
1-40 of 117Next »
Moini made it!3 months ago
This is my version - the hardest part was to find a suitable piece of wood. I used scrapings of pastel chalk instead of dirt for the little heads :D
Now I only need some space where I can display them... ;)
PaffoP4 months ago
Can you suggest a solar panel to purchase and a site to buy it from? I have been confused by what volts I need and have seen solar cells and panels for $1.50 to $37.00. I love the idea but I am not sure what to buy to make it work correctly. Thank you!
I've seen small solar panels in hardware stores in those stake lights that you just jam down into the side of the sidewalk, or what ever you want lighted. In Ace hardware, we bought some after the sales, for about $2.99. I usually see these things dressed up for holiday seasons, but wait till after they go on sale. They are generally around 2 inch x 2 inch.. Might this kind of panel work.. Home Depot, Lowes, you can find these small light sticks at most of these places.
If you can find a set of solar yard lights at a yard sale or something, you can dissect it and use the solar panel from it! A lot of people will just toss the cheap ones out when they stop working, but it's rarely the solar panel which has gone bad.
LindaS58 months ago
Very nice project. I've been wanting to do this but for usage in a garden, in the state of Md. Do you have any suggestions for how I might power those versions? I want to do them is sizes about 3 - 4 inches tall so that I can see them from inside, just to give the back yard a magical feel.. I was thinking of using some power cells easily found at your local Ace hardware, the kind that are in the cheap stake style, for power. I don't know how to wire it, but my husband probably does.. Do you have any suggestions for what I might use for the actual body of the mushroom, that light would show through.. I saw someone mention some sculpy clay, but since I want it for year round outside usage??? obviously clay isn't going to work.. Is this a doable project??? thanks to anyone answering.
Tophat12 made it!10 months ago
Advice: Pick a soft piece of wood.
fryddog1 year ago
A way to combat those bugs when making anything from an outside piece of wood is to fill any cracks or mite holes with kerosene and let it dry out for a few days.
gwenik1 year ago
GOODMORNING.
I would like to know if it is real mushroom? or fired musroom??
thank you.
Fabien
It's a mushroom made from air-dry clay.
that's so magic...
MiguelJAS2 years ago
Thanks! That's pretty much what happened to me... I was really looking forward to building this, and it would take me quite a while to get SMD's here in Portugal, so I decided to go with what I had and I used blue leds. It doesn't look really "natural" but I'm happy with the results of this first experience.
I'm still playing with it, but here's how it looks so far.
Thanks once again for sharing such a great project and idea!
P.S.: I've been experiencing some problems trying to post a reply, so I'm sorry if you end up with a few similar ones... :p
Great instructable!!
I've been reading quite a few, trying to decide which project I'm going to take, to get back to building stuff as an hobby. This will absolutely be my first project!!
Is there a specific reason why you used SMD leds (surface mounted)?
Thanks once again for a great idea! I'll try to post some pictures after I finish mine!
supersoftdrink (author)  MiguelJAS2 years ago
I used what I could find in our messy project room... they were the only LEDs in that particular color (a yellowish green, similar to the color of fireflies or natural glowing mushrooms), and I figured the color would go really well with the mushrooms. White LEDs are brighter and make for a more functional night light, but the tiny yellow green ones were pretty and subtle.
siskk3 years ago
Love the idea...where in the heck do you get the led lights and all the know how to hook up wires??? I don't have a tech savy hubby but I think I could figure it out if I had some direction.
I'm trying to work it out too! following links from other instructables mainly - I want to make a mushroom light using up nearly dead batteries so have been trying to make a joule thief first and following the links. LED's and other components you can get from broken electricals, lights etc or new from Ebay, Radioshack in the USA or Maplins in the UK. Fimo now do an 'effects' range of polymer clays including transparent colours, glow in the dark and sparkly!
wow thats so cool :)
cdubnbird2 years ago
this truly one of the best Instructables I've ever seen, absolutely spectacular.
fsfshsyhh3 years ago
Can you help me please? i want to have LED lamps in serial
power supply 3V
forward voltage 3.2-3.4
20mA
How many leds can i light up with 3V? Do i need a resistor for that, and how many OHM? Im a really beginner and i need help.
I also don't know a whole lot about this, but i find this website most helpful
http://led.linear1.org/led.wiz
just plug in the specs for your lights and power source and it will give you what you need to know
Well done, I love the combination of wood, plastic and electronics. I am usually more verbose, but I am hungry and somewhat amazed at how good this looks.
FrozenIce3 years ago
wow dude, these ar saaweeet :D
una_amor3 years ago
Oh my word. This is so enchanting. It makes me calm. It reminds me of the iPad game "Spirits". I can imagine placing a little music box inside of it somewhere. It would make a cool night light for kids. Thank you for this great project.
shortone3 years ago
http://www.instructables.com/id/Gifts-For-Guys/
Put you in my gift guide for guys! Just thought I'd let you know :)
dmadru4 years ago
I'm Confused. Where Exactly Are The LEDs Located And Where Are The Wires That Are Connected To The LEDs Are? It Looks Fantastic By The Way!
supersoftdrink (author)  dmadru4 years ago
Are you able to see all the pictures?
The LEDs are inside the mushroom caps, glued in with hot glue. The wires go through the mushroom stems and through the log to the back. I soldered the LEDs to the wires on top of the stems and then hot glued the mushroom caps on top of the LEDs.
I Understand That But Where In The Mushroom Caps. Is The Clay Slightly Translucent?
kennan dmadru3 years ago
I can answer this. Yeah, Sculpey in the lighter colors is somewhat translucent, especially at low thicknesses.
dmadru kennan3 years ago
Thanks
I absolutely love this. I am slowly turning my office into a "wizard's study" and it seems to me that a log with luminescent mushroom growing on it would fit in quite well with the theme!
Foo_Plinger4 years ago
I have a question....just started breadboarding this tonight, using a solar light I bought at Lowes (3.99), it is a single led, with a single battery, and a photocell to turn it on at night. Picked up a telephone battery pack (3 AA's) to power 6 led's. I have that all hooked up with resistors (1/4 watt), and everything looks good, EXCEPT, the photocell won't turn the lights off/on. If I have the one led attached, the photocell turns it on/off according to the light. Once I hook up the 6 led's, it no longer turns them off. What gives? Is it the increased power, or the increased draw? Anyone have ideas to check?
Thanks.
Right. The trouble with using a photo cell is that it is itself a resistor. Each LED requires a "forward voltage" somewhere between 2 and 3.5 volts. When electricity passes though it, it consumes some amount of voltage as well, using that energy to create light. Resistors are used with LEDs to restrict how much energy passes through them, so they don't overheat when connected to a power source higher than their forward voltage. When you use more LEDs, the photocell is apparently providing enough resistance to stop them from each being able to receive their forward voltage. One way around this would be to use a transistor as an electronic switch. It can take in the signal from a photo cell, and switch a much larger power supply to the LEDs without adding very much resistance at all, so you can still use normal online LED resistor calculators.
To use a transistor, you would want to connect the LEDs and photo cell to the positive end of your power supply, then connect the negative end of your LED array (including any resistors) to the 'collector' wire of the transistor, and the photo cell in series with a resistor around 5-10kohm, connected to the transistor's base, with a high value resistor like 1mohm connecting from the base to the negative of your power supply, as well as the emitter wire from the transistor also connected to the power supply negative. A circuit like that should work with NPN transistors like the common 2n2222 a which are available for less than a cent in large quantities, so should be cheaply available anywhere.
Your reply will help me out I think, but I wanted to point out that my problem is not that the LED's won't turn ON, it's that they won't turn OFF. With just one LED the photocell works as expected, with 6 they stay on constantly, regardless of how much light the photocell is receiving.
Could you explain how you have things wired up now?
red red brown on a tan body is probably a 220 ohm resistor (red is 2, the third band, brown is *10, so 22*10=220 ohm).
http://www.csgnetwork.com/resistcolcalc.html
The tan colour means it is a carbon resistor. these are the most common and cheapest to buy.
3 volts from two AAA would barely power most -white- LEDs, even without a resistor.
Usually White LEDs require a minimum of 3.2 volts but some won't switch on till 3.5 volts. So if anyone has problems, use a third battery.
http://led.linear1.org/1led.wiz
I really like the look of this project. thanks for the instructable.
What???, I've disassembled so many products with the same parts(especially little solar garden lights) and they ALL used two AAs which also produces a combined 3 volts and they use a variety of LEDs of different types/sizes. ???
They do have slightly more complicated circuits, is there a "voltage upstepper" or whatever that component is called if such a thing exists?
They would almost have to have a dc-dc converter.
Rechargable AA batteries only hold 1.2v. For a total of 2.4v --- White LEDs are on average 3.5v devices.
Ref: http://en.wikipedia.org/wiki/Light-emitting_diode
Here is a simple tutorial for making a dc-dc booster- ideal for LEDs.
http://www.evilmadscientist.com/article.php/joulethief
I've made many of these, it's a fun little project.
The nocturnal circuit that turns on the lights is really nifty too. This is a very relyable and efficient one, you can replace the 1F cap with three rechargable batteries. http://www.beam-wiki.org/wiki/Wilf%27s_Pummer
Enjoy!
ictrewel4 years ago
Came across your article, so I decided to do one of my own. Thanks for the inspiration! Not as elaborate as yours, but plans are there for the future.
Yours is darling!!
1-40 of 117Next »
