Lumitourni Lamp. Sculptural (and Dangerous) Wood Turning by Samuel Bernier
22,809
201
25
Posted
Introduction: Lumitourni Lamp. Sculptural (and Dangerous) Wood Turning by Samuel Bernier
I like to push the manufacturing process to the extreme. My friend Gabriel Beaulieu makes african djembe as a part time job so he is a real pro with the wood lathe. We were thinking of new ways to use this great tool and came up with this complexe shape :
Step 1: The Idea
Everything seems a lot more simple on paper, so we didn't worry much about our chances of success. àThe idea was to glue a lot of scrap wood together, turn it in the shape of sn apple heart. Then cut it in four parts. Flipping each part 180 degrees so a cavity is formed in the middle. Finally turn the part again to give it a nice and round shape... here is how it went :
Step 2: Gluing
we didn't think of bringing wood clamps, se we had to create our own using treaded rods. It was a very messy job.
Step 3: Instal the Bloc
Once the bloc of scrap wood dried, we installed it onto the wood lathe. It was already becoming scary.
Step 4: First Turn
The first half hour was a nightmare. It was hard core turning to remove the edges. We still ended up with a neat hourglass shape. Cutting it in four wan't easy. We broke one blade in the process.
Step 5: Turn 2
We then glued back the four parts together to create the hallow core. The real job began. We had to be very careful not to stick the blade into the holes. Very bad injuries could happen. The model did break at a moment, but we glued it back successfully.
Step 6: The Shape
After hours of work and sanding, we got the egg shape. But we still had a few hours of sanding to remove the inner edges.
Step 7: Oil and Wires
We used an oil finish and normal equipment. We used a rollerskate bearing to give a little twist to the object. The wooden lampshade turns around the light bulb, creating a stroboscopic light. I see this object more as a woodworker experimentation than as an actual light fixture.
Step 8: Tadam!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    25 Comments
    Next time you want to split a turning into quarters glue it up but put newspaper between the bits of wood where the divisions are going to be. Then the turning will split along the paper with a gentle blow or two from a chisel.
    Szturc, you are absolutely right. This works perfectly. Care needs to be taken but it works just fine.
    Nice work. Next time you want to try inside out turning (as this is called) instead of gluing the blocks together, tape them over completely with painters tape, then recover the mess with duct tape near the ends. This will hold everything together and you will get a nice shape. Then before removing the tape and turning the blocks, sand, seal, and finish the inside first. It is too difficult after they have been turned inside. That is the method I use and it works beautifully.
    I love the finished product. Very nice.
    Good project, Samuel! I'd like to do one of these in a smaller version as a Christmas ornament.
    What are the measurements I would like to make one
    This is called inside out turning. If you cut your wood into 4 sections to start then reglue them putting 2 layers of newspaper in between each section using white or carpenters glue it is strong enough to turn but comes apart at the seam relatively easily. Turn inside out and glue permanently, no newspaper and carpenters glue, then turn the outside.
    Awesome idea I'm thinking about making a small scale one in a teardrop shape as a pendant.
    I dont mean to be a jerk but it looks just like jou copied an article out of wood turning magazine.
    Haha, woodturning magazine? Really? I never heard of that, but thanks. I guess it means I made a nice work. I did this project in 2008 for the competition « Le Bois au Naturel» in Victoriaville, Québec.. But I would like to see this article. Maybe they copied me! ;)
