Lunch Box Hovercraft
2,068
22
8
Published
Introduction: Lunch Box Hovercraft
About: I like built , break & rebuilt stuffs! Instructable is a great place to get inspiration & share my ideas!!!!
Background
Sushi from supermarket always comes with an EPS Box tray. It's kind of waste if we throw it away when we finished the sushi. Finally, I thought of a way to up-cycle the boxes, it is to make a EPS box hovercraft. With the help of my elder brother, I finally have my 1st intractable done. Woo!!
Step 1: The Materials Needed
Materials
-a EPS box tray
-a Echine micro quadcopter
-a quadcopter trasmeter
-a quadcopter battery 1s 300mah
-a bottle of nail polish
-a rubbish bag
Tools
-a screwdriver
-a marker pen
-a cutter
-a cutting plier
-a circle guide
-a ruler
-a hot glue gun
Step 2: Draw Reference Lines
-use your marker and draw vertical & horizontal centre lines
-draw 2 circles (34mm diameter) 4mm apart from the 2 centre line as photo shown
-draw a line 60mm long 15mm below the horizontal centre line
-now you have all the reference lines drawn
Step 3: Decorate Your Hovercraft
*this step is optional, & you can try whatever way you are good at to decorate your hovercraft. Don't limit your imagination.
-at this point it is the perfect time, to decorate my hovercraft, I chose to spray paint it.
-Mask tape the pattern you want, apply paint to it.
-Let it dry for 20 minutes.
-remove masking tape & the decoration is done.
Step 4: Cut the Circles
-cut out the 2 circles alone reference lines.
Step 5: Disassemble the Copter
-Cut the propeller guard out with a cutting plier.
*be careful, don't cut the tiny wires!
-Remove PCB from the main housing with a screwdriver.
Step 6: Reinforcement
-Apply tiny drops of hot glue between the wires and the PCB.
*I have a bad experience that my wire broken after several plays & they are very difficult to solder back together. So it's very important to apply glue for reinforcement.
Step 7: Make Your Chip Waterproof
In order to have your hovercraft to play in water, you need to make it waterproof
-cover your PCB with nail polish
*make sure that the nail polish cover all the visible contact points.
-Let it dry for 20-30 minutes
Step 8: The Air Bag
Now the hovercraft can work on land. But if you want it run on water surface, you need to all an air bag underneath it.
-Put your EPS box tray on the rubbish bag
-draw a square slightly bigger then the EPS box tray
-cut the square out.
Step 9: Assemble the Hovercraft
-inset the front motors into the recutted round holes
-cut a small hole on the box so that the PCB can lay flat on the box surface.
-then put a little drop of hot at the very fun end of the PCB & stick it on the box.
Step 10: Install the Boosters
-Stick the rear motors on the box as shown in photos.
Step 11: Assemble the Air Bag
-stick the plastic bag on table with masking tape
-squeeze some glue along the edges of the box
-then push the box onto the plastic bag
-let it dry for 30 seconds
-then cut the exceeded plastic bag out
-cut some small holes along the 4 corners of the box
* cut less hole first & try out the effect
Step 12: Final Step
-cut a small hole like photo to allow the battery cable lay properly inside the tray
Now the hovercraft is ready to play
-install battery & bind the hovercraft with your controller.
Step 13: Test Run & Tuning
You can make the hovercraft flow higher & run faster by cutting more holes on the bag. However, too much holes can make your hovercraft fail. Try it bit by bit until you get the optimal floating performance. My experience is 5 holes of 1cm width at each of the 4 corners is perfect for my hovercraft.
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Backpack Challenge
      Backpack Challenge
    8 Discussions
    Congratulations on your first instructable! And it seems English is not your first language, which must have added to the difficulty! I was going to say it seemed odd to make a hovercraft out of a perfectly good quadcopter, but I see you wanted to try something different, and you did it, so now I understand. Hovercraft are easier to operate, and the increased speed adds to the excitement, too. One thing you might want to experiment with is adding a plastic "skirt," like the full-size hovercraft have. This may allow for smoother operation and allow it to operate on surfaces that are a little rough. Great instructable, I hope you will keep tinkering and experimenting.
    Matlek
    11 months ago
    Great project! It goes really fast!
    Thank you for your positive comment, it is faster then I expected, it is much faster then the original Echine mini drone. It is realy fun playing with it.
    Great work! Keep going! What to see more projects from you!
    That is such a great idea for 'recycling' those fatigued drones! Love this one!
    Thanks for your comment,I felt bored playing the quadcopter. I think of other ways to play with it. Finally, I turned it to a hovercraft.
    Those look like fun! I'm surprised they are so stable and quick, I'd think the foam would flip with a hard turn but they work really well. :)
    It's encouraging to have your positive comment! I try different arrangement of the propellers & different way to control it. Some are not working good as you predict. Now it's the best I got. I just use the throttle stick for speed & the yaw for turning. Every control is on the left stick. It works wonderful. Also, the "one stick control" is perfect for younger kids!!!!
