3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Luxury Ant Farm: The mANTsion
Step 7Install the hardware
Once the paint was dry it was time to install some of the hardware.
I first attached the feet to the bottom of the windows. I took the nubs that I had cut off earlier, turned them around, and glued them into position on each of the windows. I put a screw through the back of the window into the feet to hold them in place as the glue dried.
Then I put some adhesive foam stripping all around one of the windows to make a seal to keep the sand held into place when I joined the two windows together. They were already fitting together pretty tightly, but I just wanted to be sure that sand wouldn't leak out.
Aside from adding on the hardware and building a lid for the ant farm, I could have been done with the project at this point. The ant farm was basically just two windows sandwiched together with a hole on the top and some feet to keep it upright. But, I wanted to make more than just a simple ant farm, so I kept going.
I wanted to give my ant farm curtains and a light of some kind to both illuminate what was going on inside the ant farm and give the ants an artificial sun to enjoy. I went out and bought some velvet and two cheap brass curtain rods at the fabric store. I also braided some wire together to power the light that would go inside the ant farm.
I then screwed the hooks that hold the curtain rod in place onto the window and drilled a small hole in the side of one of the windows and passed my wire through to the inside.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
896
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
