M16/M4A1 Camouflage Airsoft Gun
Introduction: M16/M4A1 Camouflage Airsoft Gun
This Instructable will tell you one of the many ways to camouflage an M16 assault rifle or M4. It is easy to do, if you have the right things. Sorry about no pictures of the actual process. I had already done it when I made this.
Step 1: What You Need
- 3 or 4 colors of paint
- masking tape
- leaves and long grass.
- An M16 rifle
- Newspaper
- A few small weights such as paperweights
Step 2: Setting Up to Paint
You are going to need an open area, like an empty space in the garage, or in your backyard. (If you paint in your garage, I recommend opening the door to let air flow.) Lay down newspaper (enough to fit your gun with 3 inches around the side). Then, lay your gun in the middle. If it is windy, use the weights to hold down the paper. Tape over the orange tip on your gun. If it is painted, the police can take it.
Step 3: First Color
Now take your first paint color. This color will overlap all the other colors, so make sure that is what you want. Now, paint LIGHTLY over the gun in small strokes. DO NOT HOLD DOWN THE BUTTON AND PAINT IN ONE SPRAY!!!! This will cause the paint to run and ruin the look of your gun. Paint both sides of your gun with the first color. (I chose black.) Let it dry.
Step 4: Laying Tape
Put tape on any of the parts you want to be the first color (black). This way, it won't be painted by the other colors. (The picture is of a pistol I painted, but it should look like that, or have less stripes. Depending on how many you want.)
Step 5: Second Color
Take your second paint color (I chose green) and paint the whole gun just as before. Once it is dry, tape leaves to the gun in the places you want to be the second color (green). If you are only using three colors, add the grass too and skip step 6.
Step 6: Third Color
Take the third color (I chose a dark brown) and do the same as the other two colors. Once dry, place the grass blades over the gun so that they start at the bottom, and end either at the top, or somewhere in the middle of the gun.
Step 7: The Final Color
Paint the entire gun over with your last color (I used a tannish color). Let it dry... and you are almost done.
Step 8: Reveal Your Masterpiece
Remove the tape, leaves, and grass. Now, look at your newly camouflaged M16 rifle, and be happy. You've done well. Thank you for reading. Check out my other Instructable on how to paint a gun tiger stripe.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    im pretty sure that isnt an M16, its an M4A1, M16s have a longer barrel, and they dont have a retractable stock. Unless its some different one that i havent seen, then id say its an M4A1.
    its nether its a C8 rifle with a carry handle instead of a scope
    but the button and mag catch and bolt catch are on the wrong side
    correct you get a high-5 for pointing it out :D
    I know it's not an M16 but what I mean when I say M16 is a rifle of that type. Mine is kind of a cross between different guns that look like that so it can't really be called a specific type.
    Abbath-you cant judge that on an airsoft gun. and if it were an m4 it would be a m4a2 because the upper reviever is different. but you were close. airsoft4ever- you used high gloss paint. i can see the shine. just fog it with low gloss paint to correct that.
    can anyone here tell me how i can stick leaves and grass on my sniper without making the tape noticeable ???
