Before I go into pros and cons I need to tell you that this is a single shot, and it DOESNT have a mag in the handle.
PROS AND CONS!
Pros:
Looks awesome
comfy
powerful
Trigger that blocks far back
quite low part use
has a bullet lock
Accurate
Cons:
Trigger is kinda different (rather than listening to a trigger click once, this one has to click twice)
Uses a lot of Y clips (not a problem for me)
Handle plates fall off sometimes (can be fixed with an elastic)
Note: this gun uses three broken white rods (two optional) and a green rod cut in half. And two broken Y clips are optional. A broken orange connector is also required. (Both tabs taken off)
GET BUILDING!
Remove these ads by
Signing UpStep 1: Handle
Picture 1: What you WILL make.
2: Make these. Make two more of each, just don't make them with white rods sticking out of them.
3: Get those. (If this is too hard maybe you shouldn't be building this XD)
4: Put those things on the other things.
5: Put the other ones on.
6: put these on each side. Note the broken Y clips. They are optional.
NEXT STEP!!!
Visit Our Store »
Go Pro Today »
you didnt its just it shows the half moon on the top in pic 2 is broken and btw check your inbox
