loading
Step 16: Number 5
The fith one is a bit easier, by now you will start seeing where the pieces go.
Here it is easier to put the pentagon in in segments of 1 or 2 pieces and attaching the pieces once they are in place.
You can see this is what I have been doing.
This definitely impresses. Very fun to make!
<p>I still can't get step 7, could you explain more. Thanks! </p>
<p>So much fun making this. Easy to fold, but quite difficult to get the fourth oentagon in right.</p>
<p>Heh, how hard can it be? #famouslastwords</p><p>Also, that's a pretty fancy pattern on the paper. How did you get it?</p>
<p>Haha this is definitely doable for your average origami folder, not too tough! I just googled &quot;granite texture&quot; and &quot;gold texture&quot; and printed them out on regular paper... The paper you use makes a world of difference to the final model, it's worthwhile getting a nice pattern :)</p>
Dude this thing is awesome!!! It took me 5 hours to make (im a bit slow) but it was really fun! I heaps of compliments on it! Please do more origami instructables because your posts are awesome!
Aah much appreciated! <br>Post a photo, i would love to see! <br>I will certainly post more interesting origami posts :) I prefer the geometric models to birds, fish etc... <br>There's a certain beauty in working with a 2 dimensional medium, its very mathematical :)
I like how you broke down something that looks impossible into doable steps. NIce job! I want to try it.
a.ma.zing!! so stoked to try this. thx for sharing!
I think while this is probably the second hardest origami model I've made (second to the kawasaki rose) it's definitely my favourite. I've suspended it from a ruler with fine cotton thread and taped the ruler to the top of my PC tower on my desk at works so now it slowly spins next to my monitor. I love how the angles come together to form the inverted pyramids where they meet.
Think I'll have to try this. How big were the squares you halved and what height did the model end up? Just so I can estimate how fiddly it will be with my size paper. Thanks.
I cut squares out of an A4 and then halved them, so about... 20cm I guess? <br>The model was quite big and there are no really small tricky folds, so you can do it with paper thats quite a lot smaller.<br>Doing the weaving will be easier with smaller paper as well, and the smaller your paper the sturdier the model...<br>I wouldn't go smaller than about 6cm squares though, unless you have very thin paper.<br>
That's great, thank you. I think I have 12 cm squares, I'll give it a go some time this week. It should look good on my desk next to my 30 unit PHiZZ ball.
Aah the 30 unit PHiZZ was one of the first modulars I built...<br>Great way of learning how the geometry of these modulars work!<br>Post a photo if you get it done!<br>
The 4th and 5th pentagons are REALLY hard to get right. I'm not sure if I've done the 4th right since it's so hard to differentiate between the units in your photos. I've connected the 4th but can't see how to integrate the 5th. It'd be much clearer if your pentagons were different colours :(
Hey!<br> If you attached the 4th one correctly the 5th one is much easier...<br> I have attached a photo of the diagrams, but they're not very good quality...<br> <br> Basically, work on the triangles that are formed, each arm goes over the next one clockwise. When you put the 3rd loop in, 2 triangles are formed, one at the top and one at the bottom. The 4th one adds another 2 triangles, next to each of the original 2.<br> <br>
Thanks, that looks like it'll help. I also reread all of your instructions and found I definitely must have put the 4th in wrong. If you hold 3 loops up by one you can see that one of them only goes through 2 not 3 others. Will have a play again tomrorow night :D
Good luck! <br>The 4th one is the hardest.... <br>What might make it easier is holding the first 3 in place with some sticky tape or something so that you have both hands free to get the fourth one in. <br>The triangles are the key. <br>If you look at the photo on step 14 (3 pentagons) the 4th one goes inside the 3 loops on the left/front and outside the 3 loops on the right/back, forming triangles at the bottom/front and at the top/back, next to the previous 2 triangles... sounds confusing I know...
I actually found 5 harder than 4. I found the tape trick, I also put some tiny dabs of glue in the joints of the pentagons to hold them together a little better, my paper's a little floppy. Sure, it's not purist, but only you and I will know ;)
Just making the parts for 6 now.
Here you go.
And this:<br> <div class="media_embed"> <iframe frameborder="0" height="315" src="http://www.youtube.com/embed/jobchG5XIN8" width="420"></iframe></div>
Looks great! If you are really up for a challenge, go try my other origami instructable ;)
I don't like the look of that one ;) I might try a half sized one of these though at some point.
Well done! Looks fantastic!
Hahahaha no problem! <br>BE CAREFUL when using glue, its unforgiving... If you make a mistake once you've glued them you're in trouble...
In the pictures the 4th pentagon is the one thats at an angle (the first 3 are relatively upright)... <br>the 5th one is easiest to put in in segments and attach them once they are in place. <br>Try to follow the symmetry, most of the segments of no.5 should form a triangle when you put them in...
Another project to try out! As soon as I'm not busy with school, work, or my life's ambitions...
Hahaha you're going to be busy for a while... <br>
This is so awesome! I look forward to what you are going to come up with next! I can't wait to try my hand at this one....eventually! :)
Ah thanks!<br>This is a whole lot easier than my previous model!<br><br>
That's partly why I think I'll start with this one! ;)
You'll enjoy it! <br>I did it in one sitting in about 6 hours, but you can spread it out, make a couple of units every day whenever you have a spare minute :)
Good to have a possible time frame! Keep the great ideas coming!
About This Instructable
22,415views
223favorites
License:
More by joettle:Modular origami sculpture: 6 rectangular prisms  Complex origami sculpture: K3 - 20 woven triangles - No glue Origami Sculpture Puzzle: 4 Intersecting Cubes
Add instructable to:
