MAKE a FLASHLIGHT THAT DOESN'T NEED REPLACEMENT BULBS OR BATTERIES!
29,859
190
27
Posted
Introduction: MAKE a FLASHLIGHT THAT DOESN'T NEED REPLACEMENT BULBS OR BATTERIES!
A couple of years ago, I made a forever flashlight mostly out of old parts I found laying around.  This was the video I made of how I built it and how it turned out.
http://www.thekingofrandom.com
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    31 Comments
    can I use any kind of magnet, sir?
    cool project anyway :)
    I wonder if you were to use two or three separate coils along the length and wire them in parallel to the Bridge Rectifier, would that help build charge more quickly? I haven't tried it, so I am just wondering your thoughts.
    thanks. because i have cameras in larger supply, i will just use a camera capacitor
    This is not near as easy as we are lead to believe. I tried this with 300 wraps, then 500, now 800 wraps before I ever got sufficient voltage. Also I tried it with 1 inch pvc and then found that 3/4 works better, and in fact I used my table saw to make a 1.5 inch groove 1/2 way through the pipe wall in the middle of the pipe so that the windings would be closer to the magnet. I recommend 28-34 gauge wire to make the winding smaller. Be advised that the smaller the wire gauge the higher the voltage, but the lower the amperage. Amperage = the actual power flow.
    I have a question or two: You didn't say where the poles of the magnet are. Are they on the ends, or the sides? Also, why did you use 1 inch pvc? The magnet fits much better into 3/4.
    Thanks
    Using a bicycle speedometer to count 300 wire wraps.
    Connect the magnet to the pvc pipe, and the sensor next to it. Make the pipe so it can easily be spun in place.
    Circumference of 26 inch bicycle wheel 81.64 (wheel diameter x 3.14)
    1 mile converted to feet 5280
    1 mile converted to inches 63360
    1 mile converted to 81.64 inch units 776.0901519
    4 tenths of a mile is this many 81.64 inch units 310.4360608
    Keep spinning the pipe until the bike speedometer says .4 of a mile, and you have sufficient wire wraps.
    What would be the result of wrapping a single wire layer down most of the length of the pvc? Better? Worse? Not workable? Just curious.
    A question, Can you use other types of capacitors? If so, what farad?
