All you need is a compact fluorescent light (CFL) and a flyback transformer.
Flyback transformers are found in TVs and CRT monitors. They make the high voltage, high frequency current necessary to trace the electron beam across the screen. They are small and compact, and you can take them out from an old computer monitor or TV.
CFLs are very popular high efficiency fluorescent lights. They are similar to their ancestor the fluorescent light tubes but use electronic ballasts instead of the big and heavy ballasts in the old technology.
The electronic ballast works by generating high frequency currents that are fed to a tiny high frequency transformer that boost the voltage and run the fluorescent tube. It is the high frequency that makes the assembly compact.
The electronic ballast generates less than 1000 volts. But by replacing the fluorescent bulb of the CFL with a flyback transformer, spectacular voltages can be achieved.
Remove these ads by
Signing UpStep 1Some Info on CFLs
Most CFLs have a similar circuit topology. All of them have 4 wires coming out of them. The wires are in pairs, and each pair connects to a filament inside the light bulb.
The CFLs I came across have the high voltage on the outer wires. You only need to connect the outer wires to the primary coil of the flyback transformer.
You will find a comprehensive description of CFL circuits on this page
http://www.amazing1.com/transformers.htm
It is the 28K089 7000v model for a mini jacobs ladder. Will hooking the CFL up to the primary wires still work??????????????????????
Alright all praise aside, I want to make a portable version of this project running off of a 12v rechargeable battery (DC). the bulb is sylvania 23watt micro cfl
I researched a power inverter that converts 12v dc to 110v but that seems impractical.
do you think i could somehow wire the 12 volt directly to the board via dc to dc step up converter?
I am looking for a circuit board diagram but i cant find any. the board looks like the Bigluz 20W.
If you can help me find any way to make this project portable ASAP I would be forever in your debt. I'm running a time sensitive project (3 days left give or take) so a quick response would be great!
Thank you man! once again great project!
I had built a layden jar with foil tape the same night which didn't work as I thought so I attached the flyback to it and the results improved by double. It still won't be enough to power a jacobs ladder but I think I'm on the right track. I hope this helps. BTW look at the circuit board that the flyback was attached to for hints as to what pin is what. I at the very least found a pin labled B+ and a few labeled "G" which helped me choose the primary ground pins....
I am done playing around with single transistor drivers as they cannot handle more than 36 volts DC battery , i am sticking with CFL or EB's and also i use homemade capacitor to make brighter sparks.
UNFORTUNATLEY I DONT HAVE THEM ANYMORE, AND EVEN IF I DID I AM NOT SURE IF I CAN OPEN THEM WITHOUT DAMAGE TO THE CASE, I SUGGEST YOU GO AND BUY ONE TO DO THIS, AND YOU CAN ALWAYS TEST IT YOURSELF ON DIFF FBT'S.
LET ME KNOW OK.....
I have mentioned many times now to you about Jimmyproton because he has an instructable that uses the same electronic ballasts we are discussing, i was hoping you would have checked his instructable, it is called How to get 100KV out of your flyback!!! VERY SIMPLE SETUP, or just type 100kv in the search box and look for this tittle.
what he says in his instructions is that the electronic ballasts will only work with FBT's that have at least 11 pins on bottom, he said he tried several 10 pins but they do not work well.
I used a 23 watt CFL bulb (FEIT Electric Conserv-Energy) and didn't cut off the wires to the tube. I found that pins A1 and A3 were the powerful pins. I connected those to my flyback transformer, and it worked! However, after running it for one minute, a component on my flyback driver exploded. I think it was because the flyback transformer was demanding too much electricity from my CFL.
Long story short, try to find a CFL bulb over 23 watts.
Red Wire
_________
| 0 0 0 9 .......|
| 0 [|||||||||||||||||||]
| 0 0 1... + + |
\_________|
| 0 0 0 9 |
| 0 1 + + |
\__________|
this transformer :
Primary the "+"
Secondary min voltage "1" , max voltage "9"
the second wire the secondary coil is the big red wire that connect to on the screen.
i hope helped you,
can you help me now? please
i bought warm white CFL and this electronic plate output is 70volt, this is ok?
i connected this to the pins and "nothing" happend i connected right the pins are right, after it i smashed my transformer with hammer and saw i connected pins right! i dont know why it dont work, pliz help
the pins are usually the ones shown on the video on these flybacks.
(the 2 last pins on the far left of the half circle)
or you could wind your own coil instead of using the built in one which could give a much better result.
