Step 2Some Info about Flyback Transformers
The challenge with the flyback transformer is to find 3 pins out of 10 to 20 pins. One pin will be the high voltage ground the other two pins will be that of the primary coil that will connect to the CFL's electronic board.
If you can get the schematic of the flyback transformer that will save you time. However you can figure out the pins by following the instructions here.
Danger - if you are going to get the flyback from a TV or CRT you need to discharge it. It can hold a dangerous charge even days after the TV or CRT is turned off (see picture for details).
And what happen if i use a 10 volt RC car battery for step 1?
But discharge just in case.
