The elastic plastic strings gives several advantages: easy tuning, good pitch stability,unbreakable, replaceable, low cost, easy to amplify, ease of portability and easy to play by anyone.
Also if anyone wishes to make professional wood construction harps and lyres see the web page
misticmodels81.com or email gumistic@yahoo.com for more information.
Remove these ads by
Signing UpStep 1MATERIALS
2- Tuner- Use 5/8 size nickel or brass plated cup-hook screws.Use the type with a washer collar molded on .The hook needs to be closed with a plier. This is necessary to tie the string to inside the loop thus formed.A 1/16 in. drill bit is needed for the holes used by this size screw.
3- Crimps- Strings are held in place using jewelry crimps. They can be u-shaped, tubes or bead crimps.They are available in art-craft stores and are economical.One crimp is used at the screw end and one at the anchor end under the disc.Plastic strings when knotted come unravelled so crimps must be used or glue in place . Long nose pliers are ok for crush-crimping.
4- Strings- I use stretch-cord made of space-age polymer found under Arts and Craft jewelry..Clear material can be colored using color perm-markers. The E-6000 glue will not soften the plastic 1mm. diameter strings.
4-Tools- See figure- Also a Dremel is ok for hole drilling. using 1/16 bit.
5- Cost of materials --under $5.00
How do you get the strings to stay on the cup screws? I'm having trouble getting mine to stay. I'm using the plastic strings - the same type that you illustrated on the materials page. I crimped one end and it just doesn't stay when I wrap it around the screw.
If I have it right - you crimp the string around the looped screw.
And it comes off. right> This can happen when the open looped screw is not closed completely with the pliers. A small slit opening remains and the string can slip thru.
My solution for that is to get a larger jawed plier and really close that slit up.
On the other hand if it is still a problem I tie the sting with a small crimp on the end in the loop then dress down the string while rotating the string counter-clock-wise. This will be fine if the slit end is opposite the winding around at the collar of the screw. Tension will hold it away. Alternately you can dropplet a small amount of goop glue on the slit and let it harden before you attach the string.
Everyone wanted to play it.
Great job, and thank you so much!! :D
I'm happy for you... keep up the good work. A lot of my mini-musical instruments can be easily made in 5 nights of effort.
Can you post a YouTube video or a emailed picture? You could become famous...
george
i'd do a video but the frisbee got really warped due to all the tension on just one side. i got a 90 on my project, and the points taken off were for the research paper lol, not the instrument. but i had a blast making it, and it ended up pretty much getting passed around the classroom haha. :D
thanks again.
Allyson
Just a note on discs.. I usually use a thicker more costly frizzbe whose walls are about 1/8 in. thick. These are now 8 years old and still easy to play.
george
I also just snapped a guitar string and I need new ones anyway so the other 5 could possibly work? no?
They also need a very low tensioning and the tuning mechanism is very simple. The steel and the non-stretchable nylons need a very high tension.
I too have to do this for Physics, hopefully it comes out good, I wanna see if I can play Hey There Deliliah on it for my grade :D
I can play it on guitar, should be simple enough to translate if I did it right, I think.
If you follow the diagram th string length is indicated as shown. The length is not too important for the device to generate the notes because the note generation is mainly adjusted by tensioning or pulling on the string end in construction then tying it or anchoring it down .
The first or lowest note string is about 3 in long . But it is not critical on length . It can be 2.5 to 3.5 inches and it will work ok.
The string itself as cut from the spool is about 3.5 inches long . It can be up to 4 in. long.and is long enough to make a anchoring and twoturns around the tuning screw after it is stretched to the desired note. Notice -you have to pull on the string and it will stretch about 1 to 5 inches beyond thebase anchor point. to get to the proper note.. In the stretched condition the string is then anchored but its length will remain as shown about 3. inches at point A note.
Hope this helps...
Here we used stretch strings for this 3 string Mini. good luck
It is a perclorethylene solvent based plastic .That means you need to be sure you have adequate ventilation while it is hardening. It is a very strong plastic after it hardens completely in about 4 hours to 5 hours. An alternate is Goop Glue that is available also in art and craft stores and hardware stores.
thanks (he called them singing telephone poles, I tried google many ways plus other search engines but no go)
thanks
sparkie
sparkie
