MAKE A MINI-HARP FROM A PLASTIC THROWING DISC
Step 2ASSEMBLY/ layout
ASSEMBLY/ layout
1-Layout- see diagram for a approximately 9 inch disc. Nothing here is very critical . Find the center of the disc. Then draw a Center-line as shown. Using a compass /dividers strick an arc. Sart the first note ,Here I used the [A] note.3.3 in. from the CL(center-line) on the top lip of the disc. Mark off .625in. spacings for the 17 Notes.. Drill 1/16 holes one-half way down from the lip at each marking.
Finally at the arc- points drill 17 holes using the 1`/16 in. bit.These are the anchor holes.They are spaced .30 inches apart.tape in a disc of paper on the inside of the disc to use for marking.
The compass-point is 2.2in. down from the center for the 3.0in. Radius arc. Drill point 'A' on the arc 2.1in. to the left of the Center point of the disc. Then mark off the .30in. spacings from 'A' pt. as shown.
2 comments
Oct 13, 2010. 10:22 PMlivestron says:
Which way are the strings suppose to turn. I have been working on this and it doesn't seem to come out correct. Can you help me?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:mistic
A retired electronics engineer -motorola. delveing into new craft ideas and contest entries.
