Step 3ASSEMBLY OF TUNER/STRINGS
2-Stringing- cut each string as needed about 2 inches longer than shown in the diagram.Make a crimp at one end using a crimp tube and pliers.Then tie a simple knot and pull tight. then rotate the string counter-clockwise two times around the top of the collar and pull string down into the anchor holes. Grab with a hemostat on the under side. Pull the string and pluck it to within one note less than the desired note.Lock the length on the underside with the hemo.Then place a u-crimp next to the locked hemo. Then remove hemo. Finally re-tune by rotating clockwise the tuner screw. This is then repeated for the remaining Note strings.Cut off the excess.
If you follow the diagram th string length is indicated as shown. The length is not too important for the device to generate the notes because the note generation is mainly adjusted by tensioning or pulling on the string end in construction then tying it or anchoring it down .
The first or lowest note string is about 3 in long . But it is not critical on length . It can be 2.5 to 3.5 inches and it will work ok.
The string itself as cut from the spool is about 3.5 inches long . It can be up to 4 in. long.and is long enough to make a anchoring and twoturns around the tuning screw after it is stretched to the desired note. Notice -you have to pull on the string and it will stretch about 1 to 5 inches beyond thebase anchor point. to get to the proper note.. In the stretched condition the string is then anchored but its length will remain as shown about 3. inches at point A note.
Hope this helps...
Here we used stretch strings for this 3 string Mini. good luck
