MAKE USB LIGHT FOR LAPTOPS IN 10 MINUTES
Published
Introduction: MAKE USB LIGHT FOR LAPTOPS IN 10 MINUTES
About: big looser my self
In this Instructables we are going to make the USB Light for the LAPTOPS. Normal USB Light Costs Minimum $ 4, But Here I am Making the USB Light with Old and Waste Materials Costs less than $ 1.Making of this USB Light is Very Very   Simple Manner and It Takes Only 10 Minutes. Use This   Light   for LAPTOP Keypads in Dark .It is Very Effective and Consumes less Power Only.
Step 1: Gathering Tools & Materials
Materials:
1. Tic Tac Hard Mint Box (Choose Normal Transparent Box)
2. White LEDs – 4 No’s (normal bright LEDs)
3. Resistors (100 Ohms)-4 No’s
4. Old USB Cable
5. Common PCB Board
6. Thin Iron Wires
7. Insulating Tapes
8. Paper Tapes (In Different Colors)
TOOLS&EQUIPMENT
-Soldering Iron
-Soldering Wire
-Hot Glue Gun
-Wire Cutter
-Hacksaw Blade
Step 2: MAKE FOLDABLE CABLE FOR LIGHT
Take the Iron Wire and Cut it into two Pieces with the Length of the USB Cable.
Take the USB Cable and Cut the Opposite Side of the USB   Port (i.e. Mini USB Port).
Place the Iron Wire around the USB Cable and Bend it in Corners.
Stick the Iron Wire with the USB Cable with Help of Insulating Tape in Two Times
Step 3: PREPARING THE USB LIGHT
Take the Common PCB Board and Cut it for Wanted Size Using Hacksaw Blade.
Solder the LEDs and Resistors as in the Circuit Diagram.
Pass the USB cable through the Tic Tac Container Cap.
In the USB Cable there are 4 Wires in Different Colors, Take Red as +ve and yellow as -ve and Make Soldering; the other two Wires are not needed, solder it separately.
Insert the Light into the Tic Tac container and Stick it using Glue Gun.
Step 4: MAKE MORE ATTRACTIVE
Cover all the Parts of the USB Light with Different Color Tapes.
Fold it for your convenient and connect it to the USB.
See the power of the USB light.
you can make this with different lenths and different color LEDs for fun.
Caution: please make the solder perfectly. Any short circuits in soldering will affect your LAPTOP’S USB port. Solder it carefully.
If any suggestion for this instructable, you will notice it in your comment .THANK YOU.
THANKS FOR MASTER. Mr. THIRUMALAI KUMAR FOR CAMERA WORK
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    You want a pro membership to download any instructables as pdf.if you not get a pro membership you should go with web page to PDF converter. It is available free in internet.
