MAKE a DROP-LEAF TABLE
1,280
40
Published
Introduction: MAKE a DROP-LEAF TABLE
About: Easy and affordable DIY projects and ideas.
It's easy to make this drop-leaf table that you can mount onto a wall. When not in use, fold the support to the side to lower the top.
YOU WILL NEED:
1 of 19* x 94 x 810mm pine - table, back
1 of 400 x 810mm laminated pine - table top
1 of 22 x 44 x 710mm pine - top 'T' support
1 of 22 x 44 x 300mm pine - bottom 'T' support
1 of 300 x 300mm laminated pine - support
1 of 22 x 44 x 100mm pine - block
4 of butt hinges and 16mm screws
4 x 40mm screws [2]
32mm pocketholes screws [5]
Wood glue
Fischer SX8 wall plugs [2] and and 75mm screws
Wood stain, sealer or varnish
Paintbrush
TOOLS:
Drill / Driver plus assorted bits
Orbital sander plus 180-grit sanding pads
Kreg pockethole jig
Tape measure and pencil
*The pine for the back and top must be the same thickness.
Step 1: MAKE THE TABLE
1. Mark the size of the half-circle you want - ours is 800mm long along the edge - and cut out with a jigsaw. Sand smooth.
2. Attach the top to the back support using butt hinges and 16mm screws, see photo.
3. Draw the table support on the remaining laminated pine. The inside mark is 40mm in from the edge. Use a jigsaw to cut out the table support. Sand smooth.
4. Secure the block onto the top of the table support 20mm from the edge, with 40mm screws. Make sure the screw head is flush with the block.
5. Attach [2] butt hinges to the back of the table support - one at the top and one at the bottom - with 16mm screws.
6. Use a pocket hole jig to drill holes at the top of the bottom 'T' piece. Secure with wood glue and 32mm pocket hole screws.
7. Secure the 'T' piece to the underside of the table back using wood glue and pocket hole screws.
8. Attach the support onto the bottom 'T' section. Make sure the support is even at the front and back.
Find more easy DIY projects on www.Home-Dzine.co.za
Step 2: FINISH AND MOUNT
To finish the table, apply wood stain, sealer or varnish in accordance with the manufacturer's recommended guidelines.
Mark the location for drilling the holes. Use a spirit level to make sure it is straight.
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    2 Discussions
    Chrome browser is not displaying all of the steps for this project, nor does it have the comment box! I had to open it in Firefox to see more than 3 pictures and materials list. If you want to see the accompanying text for each picture, you will have to go to the original site:
    http://www.home-dzine.co.za/diy-1/diy-dropleaf-table.html#top
    this would be a perfect technique for repurposing an existing table into a wall mounted drop leaf. Would be a great space saver in a small room. I'd be tempted to put some kind of latch or catch on the leg so it didn't get closed by accident.
