This is an old project that seemed halted by refusal by DLP to provide a DMD chip
to vastly increase the 3D resolution. This project has not changed at all since
before HDTV even existed. I suppose after people realize the world isn't flat, this is what
they will watch when 1800's movie technology finally gets "old".
It is simple enough to have been built entirely by not more than 2 people, in a very short
total amount of time.
It actually does project animated 3D bitmapped images into the air.
It can be made by anyone who is good at PIC programming and mechanically inclined.
It cost us NOTHING, and has potential beyond most high budget 3D display research.
It contains no parts that were not available in 1980. All were scavenged from a junk pile.
Most or All of it's 3D animations were sent 100 miles over a 14400 baud modem.
It does not stop if the modem hangs up.
It looks the same from all angles.
It has no mirrors, just one lens, which doesn't have the size limitation of a parabolic mirror.
It's a hunk of junk, but it works.
IT IS PUBLIC-DOMAINED (cc-share alike)
And, should the info be updated, a solution to the failure to acquire DLP may be included.
As well as some more of the animations that are stored in it.
That's an old 80286 laptop, used as a TTY on the right.
Remove these ads by
Signing UpStep 1Go to this website
http://holodeck.virand.com
Build a Holodeck ]
Electronic Parts used:
9-pin serial (DB9) connector
MAX232C serial data voltage level converter
INTEL 8031 PROCESSOR (with 11.092 Mhz clock crystal)
4K EPROM
256 LED's latched by...
32 of 74HC574 selected by...
2 of 74LS154
32K bytes of RAM used as 60 3D Frame buffers
OPTICAL SENSOR for vertically syncing Lens Piston via interrupt to the processor
5Volt power supply...when all LEDs are on they draw about 7 amps.
Unnecessarily ridiculous and heavy piston mechanism pushing an eyeglass lens up and down.
Protocol: Simple ASCII RS-232C at up to 19200 baud... just a couple of control commands.
A DLP-less solution will use an ancient hi-res mechanical television projection mechanism instead of LED's.
The mechanism is called a "Mirror Screw" and works differently than the helical mirror in an old 3D project on the site,
but is a cheap and low-tech alternative to DLP chips for this project.
mix something around 2 parts blue with one part red, and mix it dropwise with a clear jug of ice water until the water is purple. Then slice 1 or 2 lemons and drop the slices in the jug.
Honestly I never made it before because it is silly but now that it is
in the public domain, no one can patent "Purplemonadetm".
Anyway it's just a metaphor; selling lemonade is an archetypical
example of a traditional childhood business experience.
The Airplane
The Flying Cube!
