Step 2Get some parts ready!
Orange is kind of good too.
Yellow I think is lame.
Green is ok, the really bright green would be equal to the red
...except that your eyes will (should) be closed, and red goes thru eyelids the best.
Blue does incredibly nothing. It might make a difference with alternating colors
but I don't think that will be part of this project.
White is good, but only because the first time I made these I used white backlights,
EL type from little LCD screens, and it was actually interesting to stare into those
with eyes open.
You need a 555 timer chip. The flashing will have adjustable rate about from 1 to 20 Hz,
and a duty cycle of almost 50% on and off. Also both eyes will get flashed at. I once had
a switch to make the flashing alternate, but it required another chip, and gave me a
headache. Only one good use is that if the hallucination wears off, a few seconds of
alternating lights would temporarily prolong the effect. Another use for that would be
alternating colors, but there is a reason that that may not be a great improvement...
The alternating color effect can be hallucinated with the red alone. You'll probably
see many different colors.
You need a Pot, AKA a Volume control. Resistance 10K or a little more.
And find a nice a knob to control it with.
I don't recommend "smoking the pot" because only the current will get "high" and you'll ruin the project.
My Pot turns on and off. I just remembered all the times I fell asleep with one of these
turned on and wasting the battery a little. A good way to prevent that is use a button
that's easy to hold down that you will let go of when you snooze, and the machine
will instantly go off. Unless you want to use it for lucid dreaming practice.
I never worried about it before because I used rechargable batteries.
A circuit board would be nice, unless you're the guy who said
"the bigger the Globs, the better the Job". Sure it's possible to solder all the other stuff
on the chip and hot glue it in... the box. I really think I want this to look nice on the outside
at least, (not sleeping is making me silly) but I guess you can drill holes in the glasses and put
all the parts there, and run headphone wire to your ALTOIDS battery, and save an un-cheap box.
Then you'll really look like a Borg. Anyway I'm not really sure my battery and Pot will fit in
that box with the circuit. Of course I'm going to cut and not use most of that board for this.
Well the circuit works on a bread board now so I'll draw a schematic and "use the breadboard" now,
since it's way past time to sleep. The LEDs are the same distance apart as my eyes.
Here's all the parts I got ready already. I think all I didn't mention was a few resistors and
capacitors and maybe a diode so we don't get stupid and reverse the battery.
2x330 ohms resistors 2x1K ohm resistors 2 Red Leds One 470uF cap One 10uF cap
One 2N2222A (or any other cheap NPN transistor ... BCxxx or 2SCxxx) One 10K switch-pot
One 9 volt battery - yeah I have clips made from dead batteries but not using them today.
Add Comment
