MAKING VALVELESS PULSE-JET ENGINE
6,109
50
6
Posted in TechnologyScience
Introduction: MAKING VALVELESS PULSE-JET ENGINE
About: I think I'm a scientist... I have done many discoveries in order to say that ... so call me as the young scientist of India
hey, guys, have you heard about working on a pulse-jet engine. The idea sounds to be crazy.
you had come to a correct place now below you can see how we made a valveless pulse-jet engine
This is my first valveless pulse jet engine ( u shaped ) Lockwood-Hiller design I used stainless steel sheets for making pulse jet engine because stainless-steel is the best metal to withstand high amount of temperatures
Step 1: SELECTION OF MATERIAL
Step 2: COMBUSTION CHAMBER
selection of combustion chamber decides the size and thrust of jet engine
Step 3: U TUBES
u tubes are complicated in order to make but in this design, they are very easy to make
Step 4: AUGMENTORS
AUGMENtORS play an important role in increasing thrust or a jet engine up to about 30%
Step 5: FUELING JET ENGINE
we used LPG to start up of engine and engine runs on LPG and liquid fuel such as petrol/diesel/kerosene which is sprayed into combustion chamber using a high-pressure fuel pump.
liquid fuel injector should spray the fuel in the form of a spray. that mean correct selection of high-pressure fuel pump and fuel injector plays an important role in proper fueling a jet engineLPG cylinder with high-pressure regulator
Step 6: AIR SOURCE FOR START UP
we used a leaf blower powered using a 25cc si-engine in which we need enough air to enter the combustion chamber to initiate combustion
Step 7: IGNITION SOURCE
ignition is carried out by using a high-end transformer coil powered by a battery in order to initiate LPG fire
Step 8: TESTING
finally testing of the jet engine by starting it up and threatening people
click HERE to watch project on youtube
Thank you for watching my video. comment below for any information needed
you can follow me on Facebook ,
for any other Queries, you can EMAIL ME
THANK YOU
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    what is this part called as and how can we find it??
    6 Comments
    You won't have to worry about anyone tailgating you while riding on this. ☺
    I'm afraid we can't do that in France cos it's a bit risky, isn't it ?
    ha ha every thing is risky untill you do it
