Introduction: MBSR-2
About: I make K'nex guns, specializing in semi-automatic, RBG-Slingshot hybrid systems which i use in most of my guns. Note: I am not responsible in any way for any damage, injury, or death caused by my Instructable…
This is the second version of my MBSR (Masterdude Bullpup Sniper Rifle). It's been updated with new features such as:
-Safety
-New compact magazine
-New sight
-Cheek rest
-In-stock compartment
Pros:
-Semi-auto
-Strength
-Range
-Removable mag
-Adjustable sight
-Bi-pod
-True trigger with trigger guard
-Good comfort
-Listed above in the new things
Cons:
-Lots of pieces
-Can be hard/slow to load
More Instructables by Masterdude
Step 1: Barrel Part 1
Follow the images:
Image 1: Make 2.
Image 2: Make 3.
Image 3: Make 1.
Image 4: Add blue rods as shown.
Image 5: Place 3 of the other parts as shown.
Image 6: Cover with the other part.
Image 7: Place the last part as shown.
Image 8: On the other side, add a metallic blue clip.
Step 2: Barrel Part 2
Make the following:
Image 1: Make 9. (Part A)
Image 2: Make 9. (Part B)
Image 3: Make 9. (Part C)
Follow the images:
Image 4: Add four red rods to Part A.
Image 5: Add Parts B and C as shown.
Image 6: Add Part A and repeat this step and the earlier step while switching the sides of the Parts B and C until you get this.
Image 7: Add a red rod.
Image 8: Add a white rod as shown (for the bi-pod).
Step 3: Main Body: Components
Make the following in the quantities given. The parts will be assigned a letter for reference further on:
Image 1: Make 1.(Part A)
Image 2: Make 1.(Part B)
Image 3: Make 2.(Part C)
Image 4: Make 3.(Part D)
Image 5: Make 3.(Part E)
Image 6: Make 2.(Part F)
Image 7: Make 4.(Part G)
Image 8: Make 3.(Part H)
Image 9: Make 1.(Part I)
Image 10: Make 2.(Part J)
Image 11: Make 1.(Part K)
Image 12: Make 4.(Part L)
Image 13: Make 1.(Part M)
Step 4: Main Body: Construction
Follow the images:
Image 1: Add blue and white rods to Part A, a green connector and small gear.
Image 2: Add Part B, blue and yellow rods, and blue spacers.
Image 3: Add Parts C, D, E, F, G, H, L, and green, red, gray connectors, and yellow, blue, and white rods.
Image 4: Add Parts D, E, G, H, I, K, L, and green, red, gray connectors, and blue spacers.
Image 5: Add Parts C, D, E, F, G, H, L, and green, red, and gray connectors.
Image 6: Add Parts G and L, and blue spacers.
Image 7: Add Part M and a tan clip.
Image 8: Add Parts J and a small gear.
Image 9: Add a gray connector.
Image 10: On the other side, add 2 orange connectors, 2 blue spacers, and a metallic blue clip.
Image 11: Add a gray connector.
Image 12: Add 2 gray connectors.
Step 5: Magazine
Follow the images:
Image 1: Make 2.
Image 2: Make 2.
Image 3: Add white rods.
Image 4: Add the 2 other parts as shown.
Image 5: Cover with the last part.
Image 6: Make this.
Image 7: And also this.
Image 8: Put them together like this.
Image 9: Make this, this is the pin to hold the ammo back before loading.
Image 10: Loaded and ready to by put in the gun.
Step 6: Sight
Follow the images:
Image 1: Make one.(Part A)
Image 1: Make one.(Part B)
Image 1: Make three.(Part C)
Image 1: Make one.(Part D)
Image 5: Make these.
Image 6: Attach them to Part A , and add blue rods.
Image 7: Add Part C, light gray connectors, and a silver spacer.
Image 8: Add Parts C, D, tan clip, and blue spacers.
Image 9: Add Part C, light gray connectors, and a silver spacer.
Image 10: Add Part B.
Image 11: On other side, add tan clip.
Image 12: Add small gear.
Step 7: Bi-Pod
Follow the images:
Images 1-2: Make 2 of each.
Image 3: Put them together to get these.
Image 4: Add 4 white rods to a white connector.
Image 5: Add a gray and 2 green connectors and a hinge with a "Y" clip.
Image 6: Cover with a white connector and add 2 blue rods as shown.
Image 7: Attach red connectors as shown on both sides of the thing.
Image 8: Attach the earlier made legs as shown.
Step 8: Assembly
Step 9: Use
To load remove the mag and place the pin in the appropriate area. Now place the ammo in the mag. insert the mag into the ammo feed. Next push the white and blue rods in the ammo feed area out to the sides. Hook the rubber bands on the end of the barrel and the trigger spoke. Make sure the rubber bands are on both sides of the ammo. Once all the rubber bands are hooked push the white and blue rods back into the center. Remove the pin. Pull the trigger to fire (in case you didn't figure that out).
Note: This gun loads and shoots like my other semi-automatic guns.
Image 1: Ammo.
Image 2: Magazine with ammo.
Image 3: Rubber band hooked on barrel.
Image 4: View of ammo feed when loaded.
Image 5: View of spoke in back when loaded. Safety Engaged
Image 6: View of spoke in back when loaded. Safety Disengaged
Image 8: View through the scope.(Sorry but it's sideways, Didn't mean to have it that way)
Warning- This may cause harm or injury if misused. Do not point it at people. I am not responsible for damage, injury, or death caused by this instructable
