MCPE Infinite Water
Published
Introduction: MCPE Infinite Water
Step 1: Wall
Make a 5x3 wall
Step 2: Base
Add 3 blocks to the bottom 3
Step 3: More Blocks
Add some more on the block diagonally 1 up and out for both sides
Step 4: More Blocks
Add some more on the edges of the 3
Step 5: Removal
Remove the bottom 2 and add one in the center then a slab on the one in the center
Step 6: Water
Fill water in both sides of the hole not in the middle though
Step 7: Add a Roof
Add a roof
Step 8:
If done correctly the center water block should be regenerative
Step 9:
Just use a bucket on the visible water and it will regenerate
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    any 2 blocks of water across from each other will regenerate the center. all you need is a 3x1 trough built and a bucket
