MDF Ferris Wheel for Event
3,847
71
7
Published
Introduction: MDF Ferris Wheel for Event
About: Actually unemployed
Hi. first Again sorry about the language if you think i can use another word for a better explanation let me know.
This is an easy Ferris Wheel i made for a friend and she put candies in the basket and use it as table center in a event
i let the Corel Draw file were you can change the text and modify anything you want
i use 3.6 mm wood sticks as axis and 3mm MDF cut with laser, sand with Fandeli J86 and for finish A400
it´s really easy for assemble just add some white glue (Henkel Bully, Resistol 850) watch with the fingerprints its easy to get the hands full of glue
first make all the baskets and cut the wood stick let 5 mm (2.5 mm each side) for make the move easy at the end
assemble the base and that´s all
good luck
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
7 Comments
Hi Eduardo
Looks fantastic and would like to cut one as well
I would like to download to cut but keeps going into a zip file, is it possible to post only the file, or a .dxf file
Hi stuartmeyer i export to dxf and pdf.
if you got problems with the files let a message and i try to fix it
Good luck
First time I've seen a project here using Coreldraw. Think I'm gonna try this with acrylic.Thanks.
Hi the file have the option for change the name and the date its easy in corel
Can you check the file. I don't know if it's because I'm running an older version of Corel,but it won't open and I can't import it either.
Hi. i use Corel X7 but in a minute i upload in DXF and Pdf
Good luck
