Now their have been great Instructables on this all ready such as this one, by Troy (Firgelli Automations) and his Instructable, HOW TO: Wire a DPDT rocker switch for reversing polarity found here:
But I don't think many have covered the idea of actually producing the switch itself, at least on such a scale. The photos below will show you how. Mine was used to control a large fighting robot I built for another Instructable found below.
I wanted Lil' Timmy to have a tank style feel to the controls, since it did have tank steering. Controlling it from little radio shack style DPDT switches just wouldn't cut it. I wanted these switches to have some heft to them, something I could slam hard when making turns. So i searched the internet and aside from some industrial switches nothing came close. The purchased ones were astronomical in price and even then didn't really have the heft I was looking for. So when something doesn't exist, make it it exist. Not that hard actually, with a few simple variations anyone can make it.
Remove these ads by
Signing UpStep 1Parts and Tools
Here is a list of what I used, beside it are examples of what you could use to substitute items you may not have access too.
Parts I used
- 4 3/4" x 4.5" bolts per switch
- 4 3/8" x 2" bolts per switch
- 4 3/8" nuts per switch
- 4 3/8" washers
- 12 3/4" nuts per switch
- 24 3/4" washers per switch
- 2 Small iron hinges - try to match them so they are the same width as the tabs below, preferable with 2 holes per hinge leaf
- 2 Tabs of iron plate about 1" x 4" about 1/4" thick, per switch
- 1 Piece of 1/4" plywood about 2" x 3", per switch
- 1 Piece of plywood 3/8" thick and at least 8" x 5" per switch, of course if you want a series of switches, mine was a piece 8" x 10"
- 1 length of 3/8" steel rod about 7-8" long per switch
- 1 Handle, I used 2.5" x 3" barrel type bearings, you could use anything, bored out pool balls, shrunken voodoo head perhaps
- 1 Small tube of 2 part 5 minute epoxy
Tools I used:
* Drill and assorted bits, for drilling steel and wood
* Saw, to cut the plywood
* Angle grinder with a zip-cut disc
* Hobby grade or better device to weld with. OPTIONAL as one could braze, or perhaps even solder with epoxy used to re-enforce it.
* Basic hand tools, especially a socket and ratchet to match your bolts, for quicker connections
(The dog's a little odd, yes, but nobody ever said it was alive!)
Thought from first glance that the handles & shafts were made from rubber-headed mallets! I guess that would work...
Impressive.
