METAL MELTER!
49,384
292
69
Published
Introduction: METAL MELTER!
About: Random Weekend Projects
Here's a microwave oven transformer that's been modified into a dangerous little device. Now it can pump out 800 amps of electrical current, so let's use it to melt some metal!
http://www.thekingofrandom.com
Hack It! Contest
Finalist in the
Hack It! Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    Can you tell me what power supply is needed to run this unit? thanks, it's the only thing i am not sure of.
    69 Comments
    Hello Wildfire Phoenix here. This looks really cool and is something that I will do with microwave transformers (definitely an array of them).
    I was wondering could someone, swap the plug for a light switch attached to a powerful car battery for this amazing metal melter?
    No transformers do not work on DC current.
    You can however use car batteries and weld with them. I won't explain the process because you can blow up the battery and get blinded by the acid.
    I built an arc welder from 6 microwave oven transformers.
    Would more turns on the secondary give more current?What about more turns in the primary?Can the core be solid steel instead of laminated?Lotsa questions,but I'm looking for more amps,and since I have a mill,thinking of scaling up the MOT to 2x size with a custom core if possible or feasible.
    keep the primary the same, if you want a higher current ( at lower voltage ) output then reduce the secondary winds. NOOOOO! if you use a solid steel core than you'd be wasting half the energy by inducing eddy current which generate heat in the core.
    The way I understand transformers, it's all about the ratio of the windings (primary to secondary). So if you maintain the amount of windings on the primary and increase the windings on the secondary, then yes, the current increases. In terms of the core, solid steel becomes permanently magnetized if exposed to a powerful enough magnetic field.
    When I made this it was really loud and got really hot quickly. I cut the transformer apart with a grinder. Maybe that was a mistake, is the reason for all those thin ply of insulated metal to reduce eddie current induced excess heating of the transformer? I barely know what Im saying there but Im thinking thats correct because it got real hot real quick.
    this thing is awesome! i used 14 awg 3 conductor copper wire, and paralleled all 3 conductors. the max short circuit current is 460 amps at 3.69 volts. it easily melts nails.
    love your youtube channel, I thought that metal foundry would be great for prototyping parts for projects, good job Grant :3
    It is a good demonstration piece for showing low voltage with high current
    Would this work as a smelter for iron? I have a bunch of rebar lying around, and I'm thinking of trying to melt it down into blocks, then forge them into swords.
    have any experience with flybacks
    @Wildfire: If you mean using a car battery as a power source, then I would say no. The voltage you would be getting out of the secondary would be way too low to penetrate anything.
    Well done, sir -- you've earned another fan! The true gem for me though, at the end of the video: high temp solder! *smacks forehead* Thank you for solving the mystery of those PCBs in my parts bin, that my soldering iron won't touch! lol! Do you suppose that components de-soldered with your MMMOT are still any good?
    Could this be adapted to make a metal melting furnace?
    A high speed furnace would be so awesome! And handy!
    It works quite well, and I've not managed to break it yet, and I am only using 4ish gauge wire.
    I browse Instructables quite a bit, but I've never bothered to make an account. I made one though, just to comment here.
    I saw this project, and remembered I had a MOT somewhere. I found it the other day, and I decided to modify it. The only tools I had to work with were a 10 year old hacksaw with a dulled blade, and a hammer. 6 hours of intermittent hacksawing and bashing later, and the weld was finally broken! I tapped the primary out with ease, but the secondary was a different story. I sawed and bashed and did everything I could with my tools to it. No luck whatsoever with getting that out. All I managed to do was wedge it in a bit better. I decided to make a trip to the hardware store, and pick up some cable and some tools. I got a chisel, a new blade, and a rubber mallet. That still wasn't enough to bash out the secondary though. I even tried drilling it out a bit, but that was useless. So I decided to bake it at 250 for about an hour, When it came out, I slowly chiseled and hammered and pried away at the secondary, until finally it was all gone. I now wish I had taken a picture of the huge pile of copper strands all over my workbench. From there, it was an extremely easy build. I cable-tied the transformer back together once I was done, and I was ready. At that point it was about midnight, so I figured I would have to wait until the morning. Morning's soon, so I'll let you know if it works or not once I test it! Wow, I've just written a bit of a novel here.
    tl;dr: It is extremely difficult to build one of these without the proper tools. Buy the right tools, and bake the MOT in an oven for a bit if the secondary is stuck.
    Could you add a clamp on one cord like the one welding machines and some sort of tip on the other cord so this could work like a plasma cutter? :-)
    Can you wire it in parallel or series of a MOT with its original secondary to get 800 amps@ 2000 volts?
    Is it just mine, or does you transformer also make a vibrating humming noise? I used two gauge wire as you did, and mine makes a loud humming/vibrating noise. Is that suppose to happen?
