3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MIB Halloween costume
Step 2Pulsar Blaster
Pulsar Blaster
My blaster of choice! The blaster body is made from two lengths of PVC pipe that are glued and screwed together. Then glue a piece of Sintra (use PVC cement) to create the flat section between the two PVC pipes (this is the Bondo covered section in the photo.)The bottom section is notched out and some Sintra sheet is then glued in and then a piece of MDF is epoxied and screwed to the flat Sintra sheet. This notched out section is what holds the slide on the bottom of the blaster.
The slide handle is made from a cut section of PVC pipe with ribs glued on. It has a piece of MDF glued inside it to hold the bearings for the slide. The slide itself is a surplus computer rack part I found at an electronics surplus store- a drawer slide might work as well (or just screw on the handle to the bottom of the blaster if you don't want it to move.)
1 comment
Mar 18, 2010. 4:17 PMbendog38 says:
 What about the clip?   How do you make that?    And what about the ammunition and how to get that in there?     Also, the grip, trigger and handle?     How do you get those on and how do you make them????
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
