3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MIB Halloween costume
Step 5Tri Barrel Blaster
Tri Barrel Blaster
This blaster is built much in the same way as the Pulsar Blaster. First make the barrels from some PVC pipe and glue some PVC couplings onto both ends. The main body of the blaster is made from hollowed out sections of MDF that are glued together and then sanded smooth on the outside ( a belt sander works wonders here.) The front face of the blaster body then has three holes bored into it to accept the PVC barrels, which are epoxied into place. The blue dome was made by squirting some blue dye into some clear casting resin- a cheap dome light was used for a mold.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
