Introduction: MINI FLASH BANG
Picture of MINI FLASH BANG
this FLASH BANG is made from a simple party popper that u can find for 1 dollar at the dollar store. Its really simple to make
Step 1: The Materails You Will Need
Picture of The Materails You Will Need
first you will need a party pistol they come in a pack of 4. You also need a scalpel to take out the tab in the front
Step 2: Taking Out the Confette
Picture of Taking Out the Confette
Now you need to take out the confette and be sure not to pull the string at the back. With the pistol you need to take off the paper the peal off the tape on the back of the trigger BE carfull with this !!!!
Step 3: Taking Out the Fuse
Picture of Taking Out the Fuse
once you just have the base of the product gently take out the string with the fuse on it out !!!
Step 4: Final Product
Picture of Final Product
OK once you take it out light the string and throw. Their will be a small flash
admin (author)2009-06-04
Hey, this is a great instructable and is very informative. Just one thing is missing... pictures! It really helps a lot when trying to follow directions so you should consider taking some photographs. Once you do that and leave me a message when you have so that we can publish your work. Thanks! Thanks for the cool instructable and we hope to publish this soon!
stoker221 (author)admin2009-06-04
already did
grentes (author)stoker2212009-08-06
About how many of the fuses with string would you have the tie together to make a small mineral recovery explosive to save digging. I do metal detecting and the ground here can be pretting much rock and rock solid clay at times.
stoker221 (author)grentes2009-08-10
if you want that you would need about 50 to 65 it would take a while to do tho
chibiwind (author)stoker2212009-10-27
there are far better explosives you could use for this purpose, party poppers are just far too weak
admin (author)2009-06-08
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
joepetemitch (author)2013-10-12
Good Idea I did this when I was about eight and was fiddling with it in my fingers and I went of and a almost messed myself
absolutely-nobody (author)2009-06-12
could this be used as a detonator or fuse?
certainly!
i like to use these for tripwire detonators
yes it could
chibiwind (author)stoker2212009-09-04
I've tried it before, and i have a problem where most of the time the string/fuse burns a little and doesn't make it to the end, and if it does it doesn't pop.
lord voldamort (author)chibiwind2009-10-11
when i tried this, i realized the string was NYLON so it wont burn, but melt
Colonel88 (author)2009-11-29
This is more of a "FLASHER" since you didn't put if This will probably work better if you wrappes some cap gun caps around it.
About This Instructable
4,922views
10favorites
License:
More by stoker221:MINI FLASH BANG
Add instructable to:
