3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MINI-MUFFIN CRAYONS... A New Life for Broken Crayons!
Step 4MELT THE CRAYONS
MELT THE CRAYONS
-Put on an oven mitt and place the mini-muffin tin in your pre-heated 275 degree oven.
-The crayons should be melted in about 10-13 minutes.
-Only an adult should remove the melted crayons from the oven! Carefully place the hot muffin tin on a heat resistant surface and let cool for about 25 minutes. Then place tin in your refrigerator or freezer for about 5-10 minutes. If you place in the refrigerator/freezer before cooled- the muffins may crack from the extreme temp. change.
-Invert the muffin tin onto a dish towel covered surface and the chilled mini-muffin sized crayons should fall right out. The dish towel lessens the surface impact as the crayons fall from the tin.
*Great way to use dull and broken crayons brought home by students at the end of the school year!
*Wrap the mini-muffin crayons in clear plastic bags and tie with a ribbon and use as birthday favors!
*Any muffin tin shape or oven safe candy mold will work for this easy project...just remember to monitor while "baking" if your pan/tin is smaller.
*Since crayons are non-toxic you should not have to worry about baking real muffins in your favorite tin.
5 comments
May 5, 2012. 11:20 AMkaylaangelkisses says:
Amazing! I've heard off this type of re-using before, but never tried it. In a couple hours, after i find some crayons, I will.
May 2, 2010. 11:16 AMEmma456 says:
Can you use cupcake liners?
Dec 15, 2009. 9:31 PMfragile.ecstasy says:
Could you do this with paper cupcake liners inside of the tin, or would it mess up the paper and/or permanently fuse it to the crayons? I want to do this for my daughter's birthday, and I have hundreds of those little liners I'd love to use up.
Dec 23, 2009. 12:13 PMian7720 says:
Hey, I made a batch of these using the liners and they ended up working out fine. The reason I used them is because I was hoping they would be a little bit less messy, but in the end they really didn't seem to end up helping.
Dec 18, 2009. 4:25 AMfragile.ecstasy says:
does anyone know a good way to keep the larger side of this (the side that is on top in the pan) smooth? I noticed all the photos I can find of these here or in etsy/hyena shops show the pan side only, so maybe it isn't just me? I'm sure they'll smooth out with use, but is there anyway to have them come out level?
May 5, 2012. 4:21 PMkaylaangelkisses says:
I just finished, and I just melted them down for 13 minutes. I used a diffrent caryon for one and it didn't melt compleatly. Then I left it on the counter for 15 min like it said, and put it straight in the frezzer a.s.a.p and i left it in there for 40 min by acdent. Some broke but it was so smooth.
_________________________________________
Wa wawa wa.wa wa wawawa wa wa wawa do de do.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:AlwaysAllTheTimeCrafting
No time to clean the house...always, all the time crafting!
