This Instructable illustrates the steps in making a stringed instrument to which piano keys are added and played like a piano over 2 octaves. This Instructable is based on my earlier Instructable on making a mini-zither {posted Aug.5, 2009. but adds keys.
Remove these ads by
Signing UpStep 1MATERIALS-Preliminary instructions
A little input here is required. A true piano has keys that strike the wire strings. I have deviated from this mechanism by inventing a different method of sounding the string note. It entails a novel method of grabbing the string with an adhesive pad that then pulls the string up , releases it to sound a note.The adhesive I have chosen is Uglu (r) by Mactac {www.ugluit.com} .Packages for a dollar are available from craft stores.
Packages contain enough adhesive strips for several instruments. Other adhesive tapes (two-sided) can be used as Scotch[R] mounting adhesive or Foam- tapes for mounting pictures on a wall.
Lifting arm- Use coffee-stirring sticks of wood.See details in note book.
Tubing - again I found stir sticks of plastic would work that a coat-hanger wire would feed in-to. Wire is used as an axle for the keys to rotate on.
Gluing the wood sticks to the tubes is done with paste type adhesives as two part epoxy. {Eclectic Products Super-mend epoxy.}
Keys- Use vertically mounted wood sticks glue to end.
Weights- used for application of downward force to the glue tipped wood sticks onto the strings.I found Plumbers solder to be easily formed to correct weight. I experimented with wire springs and found them hard to set correct down pressure.
Overall covering- any plastic and cardboard to locate the keys as in a piano.
I have made another "piano" oops Harpsichord " too later. see Inst'bl.
It included the half notes [ # b] keys. Still sounds good after 3 years use.
sorry I could not answer sooner. Striking the string with a hammer is something i have tried .It wont make a sufficiently loud sound unless an amplifier mike combo is used. It is possible though. The key to hammer mechanical concept is possible but complicated and i gave up on that. Then i just went back to plucking using the adhesive tips and simple levers.
let me know if you have any leverage ideas to strike.
I experimented with reverse of the pluck from string by having the lever suspended above the string and the key would push tthe adhesive tip down onto the string and then pull up and release to cause the string to vibrate.How ever i could not mute the string vibration when i want a quarter note.
I have been studying upright mechanisms for a few weeks(on and off) and have come up with a design or two, but i have to get the materials to make it before i can test it. If you know a program that could do that, it would be very appreciated.
Press 1/2 inch down from top on Cnote.. strum it- presto you hear a C# note.
Does it have dynamics?
Basically, I added steel pin dividers between the keys to allign them more easily on the strings. Also am learning to draw blueprints using Paint.Net.
I will let u know.and I will add to the Inst.
Aesthetic details cost much, and in my opinion are secondary in this case.
I do not know about the effects of time on the adhesion properties of the mounting tape adhesives but they are used for years to hold up pictures,coat hooks, etc. and dont lose their adhesion .
All my projects are essentially prototypes aesthetics comes later.
