3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MINI-PIANO
Step 3ASSEMBLY OF KEYS
ASSEMBLY OF KEYS
Assembly of keys and  adhesive tapes.
1-layout  of sticks for each note.
     Apply a square of tape to ends of all sticks
    lay sticks side-by-side  so they are spaced  1/2 inch apart , with one end  with adhesive  touches a string. Apply a strip of  scotch clear tape over the sticks on the arrangment outlined.Carfully remove the assembly of sticks  and lay  on a flat surface.Dont let the adhesive stick tips touch anything.
2- Assembly of sticks to the plastic tubing-  lay tubing across sticks and apply glue under each stick and over the tubing .
3-sepparting  sticks- Use Exacto blade and cut beteen each stick. Run  the coat-hanger wire through the tubes after the assembly is placed into mounting rsonator.
4-Weights are added-Cut to length and fold 3 times and glue to ends of sticks.
5- Keys. cut some sticks and mount  sideways  with Goop adhesives.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:mistic
A retired electronics engineer -motorola. delveing into new craft ideas and contest entries.
