how it works: "Electricity flows into C1 until a high voltage is seen across G1. When this voltage is high enough, a spark jumps across the gap and allows C1 to discharge into L1 and L2. The voltage "bounces" back and forth at an extremely high rate. When the rate of discharge between C1 and L1 matches the rate of C1 and L2, the two circuits are said to be "in resonance" and the voltage goes up through the roof."
DANGER HIGH VOLTAGE: although the amps are relatively "low" this can still be dangerous. always turn it off before making adjustments unless you are experienced. I TAKE NO RESPONSIBILITY IF YOU GET HURT!
Remove these ads by
Signing UpStep 1: You will need...
a 9.5in x .9in (od) PVC pipe
15 high voltage capacitors
matching round head bolts
wood
a bottle
2 pens
electrical tape
speaker wire
about 300ft of 32 awg mag wire
18 awg solid core hook up wire
tools:
saw
knife
drill
hot glue gun
different drill bits
power source:
flyback driver or
NST
(1-10kv)
Visit Our Store »
Go Pro Today »
considering doing this with my science club
but we have VERY limited funds
ty in advance
http://www.ebay.com/itm/2Conductor-18AWG-Solid-Bard-Copper-500FT-UL-Listed-Wire-/190556711734?pt=LH_DefaultDomain_0&hash=item2c5e10ab36
copper tube with 10 turns secondary made with 2inch PVC pipe.Winding
height 10.2inch(0.315mm enameled copper wire used) also made Capacitor
bank with 2kv 0.15uF polyester film capacitor.But the problem is my
Capacitor burnt several times but the coil works with LEYDEN JAR
capacitor.Why the capacitor burning??????
Please Help Me!!!!!!!!!!!!!!!
hii !!! i have secondary on a 2.5 inch PVC and my toroid is made of aluminum duct . now i want to know whether there is any electrical connection between these 2 . how should i mount the toroid on the secondary ??
sparks.
what about grounding ? is it primary coil or secondary coil or capacitor to be grounded?
and what are the things that we people be careful of while making this stuff.
1) can i use a series of 400V capacitance for primary ?
2) what should be the value and current rating of my bleeder resistance ( connected accross capacitance)
3) how do i limit the current ; provided i dont noe whether my transformer can limit the current or not ... ?? if using a choke what would be a good value of the choke and its rating ??
4) can i wind primary on a wooden structure or do i need acrylic sheet or Bakelite ???
5) how do i tune my tesla coil ... i have no access to occilioscope :( :(
thanx alot BTW for sharing your experience !!!
2-10M ohm resistor is what most use.
3-sorry I do not know the answer to that.
4-anything non-conductive should work just fine.
5-to tune your Tesla Coil you can adjust where the connection is on the primary, you can change the capacitance of the capacitor bank, and you can adjust the width of the spark gap, you could also experiment with different sized toroids.
Do you have any pictures?
P.S. i am the same person as AWeis but i wanted an actual account for me and my friend to post, on what we make.
Thanks a lot
thanx in advance
http://www.instructables.com/id/High-Voltage-Power-Supply-For-Marx-Generator/
is there any sort of voltage multiplier that runs off of dc instead of ac?
would a MOT work with a flyback driver?
Here are some links to help you out. It sounds like there's a lot you still have a lot to learn (no offense).
http://www.instructables.com/id/High-Voltage-1/
http://www.instructables.com/id/Quick-and-Dirty-Hand-Held-quotTesla-Coilquot/
http://www.instructables.com/id/Tesla-Coil-Projects/
http://www.instructables.com/id/Tesla-Coils-for-Dummies/
http://www.instructables.com/id/How-to-build-a-Tesla-Coil/
Or you could just get one of these:
http://www.teachersource.com/ElectricityAndMagnetism/TeslaCoils/OudinCoil_InchTeslaCoilInchwSafetySwitch.aspx
it was the stupid paint computer program
and i dont understand one thing, does a tesla coil run off ac or dc?
it is possible to run DC tesla coils but i used a 9.5kV DC power supply and i didnt work at all but with a 2kV ac power supply i got the results in the picture
and would 2-3 NSTs in series make bigger sparks?
i you put them in series you will probably overload the NST and if you dont depending on the combined voltage it may be to powerful for the coil, 6-15kV is the most common voltages for tesla coils, one should be good.
so i was wondering if i had one nst running to the input of another nst, if that would increase my power, or if i just connected one output of the first nst to one output of the other, then short out the other 2 leads with the jacobs ladder, if that would increase my spark length.
and could i run the output of the nst to a mot?
i wasn't going to get one until i knew for sure if i could use it with my nst.
i was gonna get it from a garage sale or something
about 20 a week advertised in the paper about 10 more not in the paper
do you know of any such circuit?
i just want 12v dc to 12v ac
what i have now is about 1" diameter for the secondary
I also have some reservations about how the author sugests that some things are not critical, (Like the capacitance? And the Earthing connection at the Transformer?) Some of which could affect the safe functioning of the device. Do you know WHY you should use round headed bolts for your spark gap, and indeed for most of your exposed connections? If not, you should go look it up before doing anything else with this machine.
Some explaination of who Tesla was, how a Tesla Coil works, and some of the every day devices that use these principles would be nice.
Aside from that; for those who DO know about these things, this is an interesting explaination of a simple Tesla Coil, with some very clever use of available materials. The addition of more information for those who don't would make this a REALLY interesting Instructable.
sorry if i sound aggressive...
Your machine could certainly be more efficient and someone else following this instructable with only slightly different materials on hand could end up with a very different beast. As such I wouldn't reccomend testing it with your finger as you suggest in your final step, (quite appart from the fact that if someone got the circuit wrong or some of the components were faulty there could be mains electricity at that point) an earthed and insulated electrode that can be brought near to the globe without danger of drawing a spark to flesh would be safer.
Regarding the capacitors, it's a perfectly acceptable solution, and one that is widely used for modern coil circuits (well done for adding the other links there) but the capacitance of the circuit, combined with the ratio of turns in the primary and the secondary, along with the size of the spark gap will all have a significant effect on the output. One modification you might consider is to use a heavier gauge of wire in the primary coil but leave it un-insulated, so that the supply and return from the tank circuit can be connected to it at different points, alternatively make several different coils with different shapes (cylindrical like this one, flat, and conic?) to see how that affects your machine.
As for "Round headed bolts" and generally avoiding any pointy bits, the key phrase is Corona Discharge which will sap the efficiency of your machine.
Generally speaking, I think you've been lucky to get this to work so easily, you just happen to have hit upon a random combination of capacitors, coil ratio and other aspects that all seem to work together. Congratulations are definitely in order. I assure you it doesn't always work like that.
