Introduction: Mint Tin Constellation Box
Picture of Mint Tin Constellation Box
Things you'll need:
  • Mint Tin (I'm using the Eclipse Mint Tin here)
  • LEDs x 2 (Depending on the size of your mint tin)
  • Switch
  • Wires
  • 3V button battery
  • Button battery holder
  • Drill
  • Soldering iron and solder
  • Scissors
  • Clipper (optional)
  • Plier (optional)
  • Hot-glue gun (optional)
  • White paper
  • Electrical tape
Step 1: Marking
Picture of Marking
Dot the stars of your chosen constellation on the tin using a marker. You can print out a template, but I decided to draw The Big Dipper by myself. Also, mark the place where you want to place your switch.
Step 2: Drilling
Picture of Drilling
Drill the holes. The clipper and plier might come in handy.
Step 3: Soldering
Picture of Soldering
First, solder two red wires together. Repeat for the black wires (or whatever colour you use). Then, solder the wires to the positive (longer leg) and the negative (shorter leg) of the LEDs as shown in the photo. After that, solder the positive wire to the outer leg of the 3-legged switch. Solder another wire to the middle leg.
Step 4: More Soldering
Picture of More Soldering
Solder the black (negative) wire to the negative side of the battery holder and the red (positive) wire to the positive side.
Step 5: Insulating
Picture of Insulating
I tried sticking electrical tape onto the tin, but the stars ended up looking like red giants. So, to avoid this, wrap only the exposed parts with tape. (If you're using white electrical tape, you can probably just stick them on the tin).
Step 6: Hot-glueing (optional)
Picture of Hot-glueing (optional)
Since the hole I drilled for the switch is a little too big (in order to insert the switch from inside the tin), I'll have to use some hot-glue to secure it.
Step 7: Insert a White Paper
Picture of Insert a White Paper
Some stars still appear as red giants as I'm using red electrical tape, so I decided to insert a white paper in front of the LEDs.
Step 8: Done!
Picture of Done!
About This Instructable
335views
5favorites
License:
Bio: I like making things and I'm good at breaking things.
More by NeroliKo:Dark Detecting LED DecorationBamboo Coasters Stationery HolderPVC Selfie Stick Tripod
Add instructable to:
